MapServer compilation failed on mapparser.c
Frank Warmerdam
warmerdam at POBOX.COM
Mon Nov 12 08:52:52 EST 2007
Normand Savard wrote:
> Just to let you know that MapServer compilation failed on mapparser.c
> with the following error message.
Norm,
Is the problem in trunk or mapserver-5.0 branch? Or perhaps it relates
to a mapserver release tarball? I checked the mapparser.c in trunk and
5.0 branch and neither have a "<<" at line 557 of mapparser.c.
I also wonder if you might have locally recreated mapparser.c from
mapparser.y with an inappropriate version of bison.
Best regards,
> gcc -c -O2 -fPIC -Wall -DHAVE_VSNPRINTF -DNEED_STRLCAT -DUSE_EPPL
> -DUSE_PROJ -DUSE_WMS_SVR -DUSE_WMS_LYR -DUSE_WFS_SVR -DUSE_WFS_LYR
> -DUSE_WCS_SVR
> -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT
> -DGD_HAS_FTEX_XSHOW -DGD_HAS_GDIMAGEGIFPTR -DGD_HAS_GETBITMAPFONTS
> -DUSE_OGR -DUSE_GDAL -DUSE_GEOS -DUSE_ICONV -DUSE_POSTGIS
> -DUSE_ZLIB -I/home/testsuite/fgs-mshead/built/gd//include
> -I/home/testsuite/fgs-mshead/built/proj/include
> -I/mnt/hdc1/fgs-mshead/built/gdal/include
> -I/mnt/hdc1/fgs-mshead/built/postgresql/include
> -I/mnt/hdc1/fgs-mshead/built/curl/include
> -I/home/testsuite/fgs-mshead/built/geos/include
> -I/home/testsuite/fgs-mshead/built/libiconv//include mapparser.c -o
> mapparser.o
> mapparser.c:557: error: syntax error before '<<' token
> mapparser.y: In function `msyyparse':
> mapparser.y:369: error: syntax error before '<<' token
> mapparser.c:905: warning: unused variable `yyresult'
> mapparser.c:1092: error: label `yyacceptlab' used but not defined
> mapparser.c:1086: error: label `yyerrlab' used but not defined
> mapparser.c:1035: error: label `yyabortlab' used but not defined
> mapparser.c:1006: error: label `yyoverflowlab' used but not defined
> mapparser.c: At top level:
and watch the world go round - Rush | President OSGeo, http://osgeo.org
