INCLUDE tag functionality extension... maybe grounds for smallish RFC
Steve Lime Steve.Lime at DNR.STATE.MN.US
Thu Nov 29 23:22:58 EST 2007
There's some merit here I think. When including files from a directory do you
only load those with a certain extension(s)? I could see running into problems when
you leave a stray editor file (e.g. an emacs .map~ file) laying around or perhaps
a script. I think a mini-RFC would be in order.
Steve
>>> Attila Csipa <plists at PROMETHEUS.ORG.YU> 11/29/07 9:30 AM >>>
For personal purposes I have somewhat extended the functionality of the
INCLUDE tag in .MAP files. Originally I needed a way to let certain people
edit certain parts of the .MAP files, but have them interfere as least as
possible. In the I ended up a solution that extends the functionality of the
INCLUDE tag. I've done that way to retain backwards syntax compatibility. The
old school solution is to have for example
MAP
 NAME 'include'
 EXTENT 0 0 500 500
 SIZE 250 250
 INCLUDE "test_include_symbols.map"
 INCLUDE "test_include_fixedlayers.map"
 INCLUDE "test_include_editablelayers.map"
END
and then you could define different access parameters for the different
included files but then you would not be able new ones transparently (it
would be IMO awkward to INCLUDE from INCLUDE-d .MAP files). So the solution
was to simply check if the INCLUDE parameter is a file or a directory. It
it's a file, include it regularly, but if it is a directory, execute an
INCLUDE for all the files present in that dir. To avoid ordering issues
accross platforms, have the filenames sorted before actual inclusion and
maintain a number-first naming scheme, much like Apache does.
MAP
 NAME 'include'
 EXTENT 0 0 500 500
 SIZE 250 250
 INCLUDE "conf/symbols/"
 INCLUDE "conf/baselayers.map"
 INCLUDE "conf/enabled_layers/"
END
and in conf/enabled_layers/ you would have files (or softlinks, if we stick to
the apache naming scheme) like
00-firstlayer.map
10-secondlayer.map
99-lastlayer.map
This also means that for example you can set rights across groups of layers by
defining rights for a directory, you can add, remove or reorder (!) layers
with simple file copy/rename commands. The only pitfall so far is the 'too
easy to break with bad syntax' factor, but that could be remedied by a
pre-inclusion syntax check (not as easy as it seems on first sight as you
might be legitimately referencing things that are actually not the included
file, but this problem exists already with the simple include). Comments ? Do
you think this patch would be worthwile to merge with the main branch ?
