problem with expression: null values in table
Bart van den Eijnden
bartvde at GMAIL.COM
Mon Oct 8 05:28:16 EDT 2007
Hi list,
I am posting this problem here since I don't know if it is an OGR problem or
a Mapserver problem.
Using Mapserver 5.0 and GDAL 1.4.1 we have an Oracle table that only
contains null values for an integer column called HINDERCATEGORIE.
The expression used in Mapserver is:
EXPRESSION ([HINDERCATEGORIE] = 1)
which will result in:
msEvalExpression: Expression parser error. Failed to parse expression: = 1
msyyparse(): Expression parser error. parse error
[bart at hades rwsnl]$ shp2img -m topografie.map -all_debug 10 -l
vaarwegwerkzaamheid_live -o /tmp/bla.png
msOGRFileOpen(vaarwegwerkzaamheid_live.ovf)...
OGROPen(/data/OGC_UMN_services/rwsnl/./vaarwegwerkzaamheid_live.ovf)
msOGRLayerClose(vaarwegwerkzaamheid_live.ovf).
msOGRFileClose(/data/OGC_UMN_services/rwsnl/./vaarwegwerkzaamheid_live.ovf,0).
msDrawMap(): Layer 3 (vaarwegwerkzaamheid_live), 0.761s
msDrawLabelCacheGD(): labelcache_map_edge_buffer = -10
msDrawMap(): Drawing Label Cache, 0.005s
msDrawMap() total time: 0.781s
The layer definition is:
LAYER
NAME "vaarwegwerkzaamheid_live"
TYPE POINT
CONNECTIONTYPE OGR
CONNECTION "vaarwegwerkzaamheid_live.ovf"
DATA "vaarwegwerkzaamheid"
PROCESSING "CLOSE_CONNECTION=DEFER"
PROJECTION
"init=epsg:28992"
END
METADATA
"WMS_TITLE" "Vaarwegwerkzaamheden - staging omgeving"
END
CLASS
NAME "Unknown"
STYLE
ANGLE 360
COLOR 0 0 0
OPACITY 100
SYMBOL "wegwerkzaamheid_3"
END
END
END
Best regards,
Bart
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20071008/78cd56d8/attachment.html
