Parallelizing calls to msDrawLayer()
Paul Spencer pspencer at DMSOLUTIONS.CA
Sat Oct 13 20:15:12 EDT 2007
David,
While you can perhaps gain some performance in a single map draw, in
most real life uses of mapserver, folks are either serving many
simultaneous requests or generating tiles in some way.  I think in
either case, the addition of multi-threaded layer draws will actually
cause contention for processor time with the multiple processes that
are serving the requests and could hurt overall performance in high
load systems.
I think that you could probably get more bang for your development
bucks by investing time in profiling the existing code.
Cheers
Paul
On 13-Oct-07, at 6:37 PM, David Fuhry wrote:
> Tamas,
>    (responses inline)
> Tamas Szekeres wrote:
>> David,
>> I consider it would be reasonable to establish such mechanism only
>> when fetching the data of the layers. Likewise currently the WMS/WFS
>> layers are pre-downloaded in parallel before starting to draw the
>> map.
>> We should have a similar approach when fetching the other layers as
>> well.
>    Yes, I noticed that WMS/WFS layers are downloaded in parallel
> before rendering begins.  And I agree, it would be advantageous to
> extend the parallel-data-fetching paradigm to all layers.
>    For non-WMS/WFS layers though, wouldn't it be a significant
> disruption to the codebase to add lines 1 and 2 into msDrawMap()?
> 1. for i=1 to layers.length (in parallel)
> 2.   data[i] = fetch_data_for_layer(i)
> 3. for i=1 to layers.length (serially)
> 4.   msDrawLayer(data[i])
>   ISTM that the data-fetching logic might be best left abstracted
> beneath msDrawLayer().
>> However pre drawing all of the layers and later copying the layers
>> over the map image seems to be much less efficient.
> Drawing n layers onto n imageObjs is no more expensive than drawing
> n layers onto one imageObj, and the former can be parallelized
> across n threads.
> Although yes, I agree that composition (the "merge" step) will cost
> something.
> I'm entertaining the idea that the time saved by parallel fetching
> & drawing might outweigh the cost of composition.
>> When using the parallel fetching approach we should deal only with
>> the
>> drivers from the aspect of the thread safety issues.
> I might be misunderstanding your point here, but... Rendering a
> layer into an independent imageObj should be a pretty independent
> operation, and could be made so if it's not now.  Glancing at the
> mapserver thread-safety FAQ, it seems there are more unsafe &
> locked components related to data-fetching drivers than there are
> for rendering.  Which makes me wonder why you suggest parallelizing
> the data-fetching but not the rendering.
> Forgive me if I'm playing a bit of devil's advocate here.  I'm
> aware that non-reentrant functions don't rewrite themselves, and
> that critical sections don't surround themselves with mutexes.
> Surely though, it ought not to be a tremendous amount amount of
> work to keep separate layer-drawing operations from stepping on
> eachothers' toes?
> Thanks,
> Dave Fuhry
>> Best regards,
>> Tamas
>> 2007/10/12, David Fuhry <dfuhry at cs.kent.edu>:
>>> Has anyone looked into parallelizing the calls to msDraw[Query]
>>> Layer()
>>> in msDrawMap()?
>>> Although I'm new to the codebase, it seems that near the top of
>>> msDrawMap(), we could launch a thread for each (non-WMS/WFS) layer,
>>> rendering the layer's output onto its own imageObj.  Then where
>>> we now
>>> call msDraw[Query]Layer, wait for thread i to complete, and
>>> compose that
>>> layer's imageObj onto the map's imageObj.
>>> In msDraw[Query]Layer(), critical sections of the mapObj (adding
>>> labels
>>> to the label cache, for instance) would need to be protected by a
>>> mutex.
>>> A threaded approach would let some layers get drawn while others are
>>> waiting on I/O or for query results, instead of the current serial
>>> approach where each layer is drawn in turn.  Multiprocessor machines
>>> could schedule the threads across all of their cores for
>>> simultaneous
>>> layer rendering.
>>> It seems this could significantly speed up common-case rendering,
>>> especially on big machines, for very little overhead.  Has there
>>> been
>>> previous work in this area, or are any major drawbacks evident?
>>> Thanks,
>>> Dave Fuhry
|Paul Spencer                          pspencer at dmsolutions.ca    |
|Chief Technology Officer                                         |
|DM Solutions Group Inc                http://www.dmsolutions.ca/ |
