USE_POINT_Z_M usability
Andreas Albarello
andreas.albarello at TERRITORIUMONLINE.COM
Fri Oct 19 11:52:28 EDT 2007
Tamas Szekeres wrote:
> Hi All,
> I guess the usability of the USE_POINT_Z_M option is quite limited
> right now, and none of the binary distributions are distributed with
> this setting enabled.
> In my opinion mapserver should work using the 3D data sources as well
> without having to recompile the source for this particular data type.
> Shouldn't we instead get rid of this option and treat every shapes as
> 2D shapes (or 3D shapes if we want)?
Tamas,
IIRC, some time ago on here or in the bug tracker someone mentioned that
enabling the two additional shapeObj members led to a *huge* performance
hit due to the bigger structures and higher memory access times even
when rendering or working only with 2D shapes. So, I don't think
enabling the z and m members per default is an option.
Best regards,
Andreas Albarello
Analysis & SW Development
Territorium Online srl/GmbH
Via Buozzi/Buozzistraße 12 - I 39100 Bolzano/Bozen
email: andreas.albarello at territoriumonline.com
web: www.territoriumonline.com
