Idea feedback (pre-RFC)
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Tue Oct 23 15:18:03 EDT 2007
I wanted to add to this reply that the limitation I mention isn't a limitation
at all. It can be done now using the webObj BROWSEFORMAT option to
set the appropriate mime-type.
So, Jan's feature request is already doable...
Steve
>>> On 10/19/2007 at 11:51 AM, in message
<47189A520200008F000106E3 at co5.dnr.state.mn.us>, Steve Lime
<Steve.Lime at DNR.STATE.MN.US> wrote:
> Different problem but it should be possible to handle now since browse
> templates
> are only one document anyway. There's no reason you can't construct a JSON
> or
> XML template. I've been doing that for a long time. With clients that manage
> size
> and extents it's not as useful as it once was but it can be done. Just use
> mode=browse
> instead of mode=map. The only limitation is that you can't set the browse
> mode
> mime-type (default is text/html) but that minor in most cases and we could
> work
> around it.
> Steve
>>>> Jan Hartmann <j.l.h.hartmann at uva.nl> 10/18/07 10:37 AM >>>
> Not sure if this is the same problem, but could this also include a way
> to return al MAP-parameters as XML or JSON? Currently, things like
> mapsize and mapextent are returned via templates, which need an extra
> template file. I could imagine to get them back directly as XML or JSON.
> Again, I'm not sure if this is the same as what Steve means, but it
> would be a nice thing nice to have.
> Jan
> Steve Lime wrote:
>> Hi all: I wanted to float an idea that I been thinking about since the
> conference and talking about KML related to CGI templates and accessing
> drivers such as GML and KML (when implemented) when processing query results.
>> Problem: 1) Currently a driver like GML isn't available to the CGI as a
> means of presenting query results. 2) The templating scheme
> (HEADER/TEMPLATE/FOOTER) for queries isn't user friendly nor is it ammenable
> to multple presentation formats. That is, one layer => one template set.
>> Solution:
>> 1) Use output format objects to define formats that can be used to output
> query results in addition to drawing images.
>> E.g.
>> OUTPUTFORMAT
>> NAME 'gml3'
>> DRIVER GML3
>> MIMETYPE 'text/xml'
>> END
>> Might need to extend that object to discriminate between map rendering and
> query formatters but that can happen in mapdraw.c and mapserv.c too. That is,
> drivers are explicitly referenced in those places so if someone tries to draw
> a map with a GML3 driver it would throw an error.
>> 2) Use the webObj QUERYFORMAT property to reference formats: 'QUERYFORMAT
> gml3'. Right now that property carries a mime-type but it could be used to
> reference a format too.
>> 3) Define a TEMPLATE driver. Basically this would just invoke the normal
> query templating scheme.
>> E.g.
>> OUTPUTFORMAT
>> NAME 'kml'
>> DRIVER TEMPLATE
>> MIMETYPE '...'
>> FILE 'myTemplate.kml'
>> END
>> OUTPUTFORMAT
>> NAME 'geojson'
>> DRIVER TEMPLATE
>> MIMETYPE 'text/plain'
>> FILE 'myTemplate.js'
>> END
>> 4) Note that in the above examples we reference a file, so I'm thinking of
> supporing a single template system for queries in addition to the current
> mechanism. To do this I'd propose 2 new template tags: [layer] and [feature].
> These would be blocks. An example might be:
>> ...old web HEADER content goes here...
>> [layer name=lakes]
>> ... old layer HEADER stuff goes here, if a layer has no results this block
> disappears...
>> [feature]
>> ...repeat this block for each feature in the result set...
>> [/feature]
>> ...old layer FOOTER stuff goes here...
>> [/layer]
>> [layer name=streams]
> disappears...
>> [feature]
>> [/feature]
>> [/layer]
>> ...old web FOOTER content goes here...
>> This would allow for relatively complex text files of any sort to be built
> from multiple layers. All the normal template tags would still be supported
> but those normally available for query results would only be valid inside a
> [feature]...[/feature]. These tags would work with existing system too but
> just wouldn't be as useful as with the 1 template idea.
>> One gotcha is that by moving the template to the output formatting object we
> loose our mechanism to mark a layer as queryable, but we've wanted to provide
> an alternative to that anyway.
>> Anyway, I see this as being much more flexible. One could define templates
> or just access drivers for GeoJSON, KML, Metacarta text files, or whatever
> with one layer defn and multiple output formats. We could add a parameter to
> the CGI to change formats easier (as opposed to map.web.queryformat).
>> Thoughts? If positive I'll write up a detailed RFC.
>> Steve
