MapServer 5.0.0-rc1 released
Daniel Morissette
dmorissette at MAPGEARS.COM
Wed Sep 5 17:47:39 EDT 2007
Hi everyone,
MapServer 5.0.0-rc1 has just been released. Yes, that's a release
candidate, and hopefully the right one! The source package is available at:
http://mapserver.gis.umn.edu/download/beta
The page above also contains links to binary distributions. They should
be updated with binaries for this beta in the next few days.
If no critical issue is found in this release candidate, then we will
officially release MapServer 5.0.0 next week. Thanks a lot to all those
who have tested previous betas and have reported their results, either
via the list or directly in Trac (bug tracker). That helps a lot...
please keep testing and sending feedback.
The complete list of changes/fixes since beta6 is included at the bottom
of this email.
As was mentioned before, our plan was to have one beta per week until
the final release of MapServer 5.0 which is planned for the week of
September 12, 2007. More details can be found in the 5.0 release plan at
http://mapserver.gis.umn.edu/development/release_plans/mapserver_5_0/release_plan/
Daniel
Version 5.0.0-rc1 (2007-09-05)
- Fixed "MinFeatureSize AUTO" labeling for polygon layers, works for polygon
annotation layers too (#2232)
- Fixed path following labels with short (2/3 character) strings (#2223)
- AGG fix a bug when rendering polygons with tiled pixmaps
- Added requirement to provide validation pattern for cgi-based attribute
queries using the layer metadata key 'qstring_validation_pattern' (#2286)
- Fixed msDebug causing a crash with VS2005 (#2287)
- Added stronger checks on libpdf version in configure script (#2278)
- Added msGetVersionInt() to MapScript (ms_GetVersionInt() in PHP) (#2279)
- _isnan prototype for MSVC builds from <float.h> #2277
- AGG: Fix a bug when rendering brushed lines with vector or pixmap symbols
(artifacts could appear on outline)
- AGG: Adjust symbol height when brushing a line with a vector symbol so
that
the line width isn't truncated
- Only include process.h on win32 (non-cygwin) systems, moved from
maptemplate.h to mapserver.h. (#2276)
