msautotest WFS spatial filters in meter projection
Normand Savard
nsavard at MAPGEARS.COM
Thu Sep 6 16:34:56 EDT 2007
I want to add some tests to cover more deeply the WFS spatial filters in
the msautotest suite. Actually all the spatial filters tests are
executed against a WFS server which has its projection in lat/long
(epsg:4326). I want to create a WFS server which has its projection in
meter. The data illustrates the Canada maritimes provinces. Frank
suggested to use epsg:3347 which is correct based on what I see in OpenEv.
The only problem I see is that the projection definition is in 4.5.0
version of proj4 library and not in 4.4.8. Is this correct to add a
dependence to this library for some of the msautotest?
Norm
