msautotest WFS spatial filters in meter projection
Normand Savard
nsavard at MAPGEARS.COM
Tue Sep 11 13:30:38 EDT 2007
Normand Savard wrote:
> I want to add some tests to cover more deeply the WFS spatial filters
> in the msautotest suite. Actually all the spatial filters tests are
> executed against a WFS server which has its projection in lat/long
> (epsg:4326). I want to create a WFS server which has its projection
> in meter. The data illustrates the Canada maritimes provinces. Frank
> suggested to use epsg:3347 which is correct based on what I see in
> OpenEv.
> The only problem I see is that the projection definition is in 4.5.0
> version of proj4 library and not in 4.4.8. Is this correct to add a
> dependence to this library for some of the msautotest?
> Norm
I didn't receive any answer to this question. Can I use this projection
eventhough its definition is in 4.5.0 version of proj4 library?
Norm
