[mapserver-dev] RFC: GMaps API for mapserv
Paul Ramsey pramsey at cleverelephant.ca
Fri Apr 11 00:48:27 EDT 2008
All,
Attached find a revised RFC, per some of the feedback I have received.
 I am a little loath to give up the simpler URL syntax from the
previous RFC (one new mode, one new parameter) so I would like to hear
back if you feel the gains in "futureness" outweigh the simplicity of
the first draft.  YAGNI says I should just do the Google version and
let the future take care of itself.
Paul
MS RFC XX: Direct tile generation for Google Maps API
:Date: 2008/04/08
:Author: Paul Ramsey
:Contact: pramsey at cleverelephant.ca
:Last Edited: 2008/04/09
:Status: Open
Overview
Using Mapserver to render data for use within alternate mapping systems is a growing use case.  A new access API could allow Google Maps users to overlay Mapserver data very simply and accurately.  Like the WMS API, the GMaps API will allow users to have a simple install'n'run option for serving data to a de facto standard user interface.
Technical Solution
The GMaps API defines a GTileLayer which can be used as an overlay or base map.  The GTileLayer supports a GTileLayerOption, tileUrlTemplate, which allows the TileLayer to be accessed using a simple URL pattern that substitutes Google's x/y/z coordinates into the request::
 http://host/tile?x={X}&y={Y}&z={Z}.png
See http://code.google.com/apis/maps/documentation/reference.html#GTileLayer
For Mapserver, the simple URL pattern will be prototyped from the Worldwind tile service form::
 http://host/cgi-bin/mapserv?map=/path/to/amp&mode=tile&interface=gmap&version=1&x={X}&y={Y}&level={Z}&layers=foo,bar
The change will add in new handling in the loadForm function for the mode, interface, version, x, y and z parameters.  Like the WMS interface, GMaps API will require PROJ to be specified, and the existence of PROJECTION defines for all layers being accessed.  Google X/Y/Z coordinates will be converted to "spherical mercator" coordinates and fed into the extent.
The result will make a Google-with-Mapserver map as easy as::
 var myLayer = new GTileLayer(null,null,null,{
  tileUrlTemplate: 'http://host/cgi-bin/mapserv?map=/path/to/amp&mode=tile&interface=gmap&version=1&x={X}&y={Y}&level={Z}&layers=foo,bar',
  isPng:true,
  opacity:0.5 });
 var map = new GMap2(document.getElementById("map"));
 map.addOverlay(new GTileLayerOverlay(myLayer));
A tile mode with interface of gmap implies the following:
* The output CRS will be set to "spherical mercator" (EPSG:900913)
* The service bounds be global in extent. The top level (0) will have 1 tile.
* The "levels" will run from 0 upwards
* The y axis of the tile coordinates will run from top to bottom
* The output tiles will be 256x256 in size
* Each zoom level will be related to parent and children by powers of two
The Mapserver tile mode API will *not* explicitly attempt to address issues of meta-tiling or cross-tile labeling. However, the following steps will be taken to try to minimize these issues:
* If PARTIALS is not set in labeling directives, it will be turned on automatically.
* Future phases will render into a target slightly larger than the tile and then clip off the extra border pixels.
Mapscript Implications
None. This affects only the CGI interface and mapserv CGI.
Files Affected
 mapserv.c
 maptile.c <new>
* Documentation will be updated to reflect the new feature
  * Mapserver CGI Reference
  * Mapserver Tile HOWTO <new>
* Test suite will be updated to exercise the new features
  * Frank Warmerdam has volunteered to do this
Backwards Compatibility Issues
None. This functionality is net new and requires no changes to existing behavior.
Bug ID
None yet.
Voting History
No vote yet.
References
* http://code.google.com/apis/maps/documentation/reference.html#GTileLayer
* http://www.worldwindcentral.com/wiki/TileService
