[mapserver-dev] Tile Access API
Paul Ramsey
pramsey at cleverelephant.ca
Tue Apr 15 14:22:29 EDT 2008
I have opened an issue here:
http://trac.osgeo.org/mapserver/ticket/2581
... and attached a working patch against trunk to implement the
functionality. I'd like to submit the attached RFC for vote and/or
further discussion at the discretion of the Chair.
Thanks!
P.
MS RFC XX: Direct tile generation for Google Maps API
:Date: 2008/04/08
:Author: Paul Ramsey
:Contact: pramsey at cleverelephant.ca
:Last Edited: 2008/04/09
:Status: Open
Overview
Technical Solution
The GMaps API defines a GTileLayer which can be used as an overlay or base map. The GTileLayer supports a GTileLayerOption, tileUrlTemplate, which allows the TileLayer to be accessed using a simple URL pattern that substitutes Google's x/y/z coordinates into the request::
http://host/tile?x={X}&y={Y}&z={Z}.png
See http://code.google.com/apis/maps/documentation/reference.html#GTileLayer
For Mapserver, the simple URL pattern will be::
http://host/cgi-bin/mapserv?map=/the.map&layers=foo,bar&mode=tile&tilemode=spheremerc&tile={X}+{Y}+{Z}
The change will add in new handling in the loadForm function for the mode, interface, version, x, y and z parameters. Like the WMS interface, GMaps API will require PROJ to be specified, and the existence of PROJECTION defines for all layers being accessed. Google X/Y/Z coordinates will be converted to "spherical mercator" coordinates and fed into the extent.
The result will make a Google-with-Mapserver map as easy as::
var myLayer = new GTileLayer(null,null,null,{
tileUrlTemplate: ' http://host/cgi-bin/mapserv?map=/the.map&layers=foo,bar&mode=tile&tilemode=spheremerc&tile={X}+{Y}+{Z}',
isPng:true,
opacity:0.5 });
var map = new GMap2(document.getElementById("map"));
map.addOverlay(new GTileLayerOverlay(myLayer));
A tile mode with interface of gmap implies the following:
* The output CRS will be set to "spherical mercator" (EPSG:900913)
* The service bounds be global in extent. The top level (0) will have 1 tile.
* The "levels" will run from 0 upwards
* The y axis of the tile coordinates will run from top to bottom
* The output tiles will be 256x256 in size
* Each zoom level will be related to parent and children by powers of two
The Mapserver tile mode API will *not* explicitly attempt to address issues of meta-tiling or cross-tile labeling. However, the following steps will be taken to try to minimize these issues:
* If PARTIALS is not set in labeling directives, it will be turned on automatically.
* PROCESSING LABEL_NO_CLIP will be turned on automatically.
* Future phases will render into a target slightly larger than the tile and then clip off the extra border pixels.
Mapscript Implications
None. This affects only the CGI interface and mapserv CGI.
Files Affected
mapserv.c
maptile.c <new>
* Documentation will be updated to reflect the new feature
* Mapserver CGI Reference
* Mapserver Tile HOWTO <new>
* Test suite will be updated to exercise the new features
* Frank Warmerdam has volunteered to do this
Backwards Compatibility Issues
None. This functionality is net new and requires no changes to existing behavior.
Bug ID
None yet.
Voting History
No vote yet.
References
* http://code.google.com/apis/maps/documentation/reference.html#GTileLayer
* http://www.worldwindcentral.com/wiki/TileService
