[mapserver-dev] Re: [mapserver-users] [SOLVED] mapserver 5.0.2 segv
using AGG
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Apr 16 15:32:36 EDT 2008
Arghhh! This bug is caused by the fact that my output format requests:
FORMATOPTION "PALETTE=/u/data/maps/palette-google-agg.txt"
and the file does not exist. I ran into this earlier and have already
written a bug on it. Sorry the SEGV is non-intuitive to the cause and I
guess I'm slow on the up take :(
Back you your regularly scheduled programing. :)
-Steve W
Stephen Woodbridge wrote:
> Moving this to the dev list ...
> As a follow up to this it is reproducible on the current nightly tarball
> also.
> So in mapgd.c lines 3595+ are:
> gdPImg =
> gdImageCreatePaletteFromTrueColor(img,dither,colorsWanted);
> /* It seems there is a bug in gd 2.0.33 and earlier that leaves the
> colors open[] flag set to one. */
> for( i = 0; i < gdPImg->colorsTotal; i++ )
> gdPImg->open[i] = 0;
> gdImagePngCtx( gdPImg, ctx );
> gdImageDestroy( gdPImg );
> It looks like the call to gdImageCreatePaletteFromTrueColor() is
> returning NULL and mapserver is not checking and dealing with this
> condition and passing gdPImg as a NULL pointer to gdImagePngCtx( gdPImg,
> ctx ); which is causing a SEGV when it is accessed.
> Running with packages on Debian Etch:
> libgd2-noxpm/stable uptodate 2.0.33-5.2
> libgd2-noxpm-dev/stable uptodate 2.0.33-5.2
> I also ran into this same problem in brief experience with Fedora 8.
> -Steve W
>> Hi all,
>> Is this a known problem? I did could not find a ticket for it. I'm
>> trying the nightly build next.
>> -Steve
>> woodbri at maps:/u/woodbri/work/mapserver-5.0.2$ gdb mapserv
>> GNU gdb 6.4.90-debian
>> Copyright (C) 2006 Free Software Foundation, Inc.
>> GDB is free software, covered by the GNU General Public License, and
>> you are
>> welcome to change it and/or distribute copies of it under certain
>> conditions.
>> Type "show copying" to see the conditions.
>> There is absolutely no warranty for GDB. Type "show warranty" for
>> details.
>> This GDB was configured as "x86_64-linux-gnu"...Using host
>> libthread_db library "/lib/libthread_db.so.1".
>> (gdb) run
>> QUERY_STRING='map=%2Fu%2Fdata%2Fmaps%2Fgoogle-agg.map&layers=all&map_imagetype=agg%2Fpng24&mode=map&mapext=-88.20558679540737+41.41346751789421+-87.09441320459264+42.28653248210579&imgext=-88.20558679540737+41.41346751789421+-87.09441320459264+42.28653248210579&map_size=700+550&imgx=350&imgy=275&imgxy=700+550'
>> > a
>> Starting program: /u/woodbri/work/mapserver-5.0.2/mapserv
>> > a
>> [Thread debugging using libthread_db enabled]
>> [New Thread 47982973225104 (LWP 20007)]
>> warning: Lowest section in /usr/lib/libicudata.so.36 is .hash at
>> 0000000000000120
>> Program received signal SIGSEGV, Segmentation fault.
>> [Switching to Thread 47982973225104 (LWP 20007)]
>> 0x00002ba3e360e733 in gdImagePngCtxEx () from /usr/lib/libgd.so.2
>> (gdb) where
>> #0 0x00002ba3e360e733 in gdImagePngCtxEx () from /usr/lib/libgd.so.2
>> #1 0x0000000000453bb3 in msSaveImageGDCtx (img=0x738040, ctx=0x6c1a90,
>> format=0x6247a0) at mapgd.c:3602
>> #2 0x0000000000453d3e in msSaveImageGD (img=0x738040,
>> filename=<value optimized out>, format=0x6247a0) at mapgd.c:3543
>> #3 0x0000000000454886 in msSaveImageAGG (img=0x738040, filename=0x0,
>> format=0x6247a0) at mapagg.cpp:2194
>> #4 0x0000000000428f5b in msSaveImage (map=0x61d560, img=0x738000,
>> filename=0x0) at maputil.c:604
>> #5 0x000000000040e8d4 in main (argc=<value optimized out>,
>> argv=<value optimized out>) at mapserv.c:1580
>> (gdb) q
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
