[mapserver-dev] Design/Re-Design consideration
Pericles S. Nacionales
naci0002 at umn.edu
Thu Apr 17 11:27:31 EDT 2008
Seems like a good idea... I think GDAL/OGR already has a module plugin
interface but GRASS is the only available module currently. Maybe
that's a route that could be looked into if GDAL/OGR is to go this route.
I have to say though, if you're compiling the library yourself, you can
compile with a minimal library support (just TIFF, JPEG, and Shapefiles,
for example).
-Perry
Stephen Woodbridge wrote:
> Hi all,
> I really like gdal and ogr. I can't say I use them all the time, but
> they work and do the job when I need them and I would be lost without
> them on some jobs. So Thanks and keep up the good work.
> I want to toss out an idea that I think would make gdal/ogr better.
> This comes from my frustration with the fact that as more formats are
> supported, the more system library dependencies that are required to
> install it. I was horrified when I went to build mapserver with wfs
> support and I only use shapefiles on postgis layers that I had to
> install gdal and that pulled in some 20-30 other system packages!!!!
> This is insane from my perspective. I don't need any of those packages
> for the work I'm doing, maybe mapserver should not require gdal for
> wfs, but I'm sure there is a good reason for that choice.
> Regardless, The idea that I want to offer is that I think it would be
> very cool from a packaging point of view if gdal/ogr could take a page
> from the PHP book and configure a directory of runtime loadable
> modules. There would be a base package and then each format or group
> of formats would be loaded at runtime if it existed in the modules
> directory. In your ./configure script you could select what optional
> modules you want to build like --with-mod=all or --with-mod=gtif or
> these might be automatically figured out from the libraries installed
> or requested.
> Then packaging would be based on the base package and and any optional
> format packages you want to install and each format package would have
> its own library dependencies. This would greatly simplify the growing
> tangle of system library and packaging dependencies and make things
> more modular from the users perspective.
> Its an idea, maybe not well thought out, it probably involves a lot of
> work on someones part. It is offered in the hopes of making gdal/ogr
> better and more accessible from users and sysadmin's perspective.
> Discuss amongst yourselves.
> Thanks,
> -Steve W
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
