[mapserver-dev] Java MapScript DLL Name on Windows
Frank Warmerdam
warmerdam at pobox.com
Thu Apr 24 23:26:05 EDT 2008
Folks,
Who is the Java MapScript maintainer? Umberto?
I'm trying to build a Java MapScript package for OSGeo4W, and I am concerned
about calling the support DLL "mapscript.dll" since this seems likely to
conflict with support DLLs for other languages (Python? C#? Perl?)
I tried modifying javamodule.i to have:
%pragma(java) jniclasscode=%{
static {
String library = System.getProperty("mapserver.library.name", "mapscri\
pt_java");
System.loadLibrary(library);
/* TODO Throw when return value not MS_SUCCESS? */
edu.umn.gis.mapscript.mapscript.msSetup();
While this builds, when I go to run Java code I still get:
C:\build\mapserver-buildkit\mapserver-5.0.2\mapscript\java\release\apps\mapserve
r\java>java -classpath ..\..\..\lib\mapscript.jar;. ShapeInfo
n:\data\esri\shape\eg_data\polygon.shp n:\data\esri\shape\eg_data\polygon.dbf
java.lang.UnsatisfiedLinkError: no mapscript in java.library.path
r\java>
Note that this does not refer to mapscript_java.dll or mapscript_java?
Any thoughts? Do any of the other bindings produce mapscript.dll that
could conflict with the Java one?
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
