[mapserver-dev] Re: Changing the connectiontype with the mapscript
interface doesn't change the vtable.
Tamas Szekeres
szekerest at gmail.com
Tue Aug 12 18:02:48 EDT 2008
Or this way ;-)
int ConnectLayer(int connectiontype,
char *library_str)
msConnectLayer(self, connectiontype, library_str);
2008/8/12 Tamas Szekeres <szekerest at gmail.com>:
> Hmmm. What I really want to do is to expose msConnectLayer in layer.i:
> char *library_str)
> const int connectiontype,
> const char *library_str)
> Tamas
>> Devs,
>> By changing the connectiontype at the SWIG interface the vtable will
>> not change accordingly so the vtable function of the old
>> connectiontype will be called.
>> Do we have a method to reset the vtable in this case or should we
>> probably implement a layerObj.setConnectionType for this purpose?
>> Best regards,
>> Tamas
