[mapserver-dev] Configuring a buildbot autobuild SVN post-commit hook
Tamas Szekeres szekerest at gmail.com
Mon Aug 25 18:46:15 EDT 2008
Howard, Mateusz,
Thank you all, great work!
Tamas
2008/8/26 Howard Butler <hobu.inc at gmail.com>:
> done with help from Mateusz.
> Howard
> On Aug 23, 2008, at 5:40 PM, Tamas Szekeres wrote:
>> Devs,
>> It would be desirable to configure a post commit hook in SVN to
>> trigger a new build at the buildbot after the commits. I think the
>> current approach for GDAL could be taken over which looks something
>> like:
>> If a commit arrives, post-commit hook sends notification to GDAL
>> buildbot. The buildbot starts timer and waits 120 secs.
>> If new commit arrives within these 120 secs, the timer is reset for
>> next 120 secs.
>> If new commit does not arrive within this period, the buildbot starts a
>> build on the telascience-quick builder.
>> Similar process run on *-full builders but the timer is set to 120
>> minutes, in order to avoid server overloads. So, new builds start
>> only if new commit does not arrive within 2 hours since last commit.
>> Unfortunately I have no access to configure neither the GDAL nor the
>> mapserver SVN at this level so I'd appreciate if someone with
>> sufficient rights would help me out by setting this up for MapServer.
>> I guess the script used by GDAL could be reused pretty much for
>> MapServer as well.  If something needs to be modified for this purpose
>> at the buildbot configuration I'll be ready to sort it out.
>> Best regards,
>> Tamas
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
