AW: AW: AW: [mapserver-dev] speed up layer
displayingpostgis-mapserver
BrainDrain
paulborodaev at gmail.com
Sat Aug 30 15:42:23 EDT 2008
I think I know what is your problem. What version of ms4w you're using?
SUSANNE wrote:
> 120 tiles are 4*30 tiles (30 tiles for covering the screen, 4 layers).
> These tiles are empty at the beginning of the project because there are no
> data. During mapping I have a routine only to update changed tiles.
> Do you have a better idea?
> Thanks for helping, Susanne Kalliany
> -----Ursprüngliche Nachricht-----
> Von: mapserver-dev-bounces at lists.osgeo.org
> [mailto:mapserver-dev-bounces at lists.osgeo.org] Im Auftrag von BrainDrain
> Gesendet: Donnerstag, 21. August 2008 13:46
> An: mapserver-dev at lists.osgeo.org
> Betreff: Re: AW: AW: [mapserver-dev] speed up layer
> why you need 120 tiles at once? for what? 120... it will take a time, but
> it
> needless in most cases to generate so many in one operation.
> and why empty?
> try to use Proj4 projection string instead of epsg code.
> SUSANNE wrote:
>> Excuse me; I sent my previous mail unintentionally!
>> I am really afraid I am doing something basically wrong; but don't know
>> how
>> to go on.
>> Thanks a lot for your help, Susanne Kalliany
>> [mailto:mapserver-dev-bounces at lists.osgeo.org] Im Auftrag von Susanne
>> Kalliany
>> Gesendet: Donnerstag, 21. August 2008 12:50
>> An: 'BrainDrain'; mapserver-dev at lists.osgeo.org
>> Betreff: AW: AW: [mapserver-dev] speed up layer displaying
>> postgis-mapserver
>> Sorry for being so nasty.
>> I did like you told:
>> LAYER
>> NAME zobject1
>> GROUP zobject1
>> STATUS ON
>> MAXSCALE 30000
>> TYPE POLYGON
>> CONNECTIONTYPE postgis
>> CONNECTION 'user=postgres password=susi dbname=tefisdb host=localhost
>> port=5432'
>> DATA 'the_geom FROM zobject1 USING UNIQUE gid1 USING SRID=31282'
>> PROCESSING 'CLOSE_CONNECTION=DEFER'
>> PROJECTION
>> 'init=epsg:31282'
>> END
>> But nevertheless for drawing 4 (empty) postgis layers -120 tiles 256*256
>> I
>> need 3.5 minutes.
>> Gesendet: Mittwoch, 20. August 2008 21:15
>> Betreff: Re: AW: [mapserver-dev] speed up layer displaying
>> postgis-mapserver
>> -how did you import your layer data into postgres table? did you use GIST
>> indexing?
>> did you use PROCESSING "CLOSE_CONNECTION=DEFER" for your layer?
>> did you reproject your data?
>> cluster <gindexname> on <tablename> - just a sql command which you can
>> run
>> in context of postgis database using psql console app or pgAgmin utils or
>> other software that helps pgsql developers. This command creates
>> "physically-allocated" gindex which can boost perfomance for large
>> layers.
>> I have some layers with 180000-190000 polygons and mapserv draws 256x256
>> tiles pretty fast for my ajax powered webapp.
>> SUSANNE wrote:
>>> Thanks a lot for reply!
>>> I inserted following line and now postgis query works fine.
>>> "DATA 'the_geom FROM zobject1 USING UNIQUE gid USING SRID=31282'"
>>> But I don't get on with optimization.
>>> On which place do I have to insert: "cluster gindexname on tablename" ?
>>> I inserted in postgresql.conf:
>>> # AUTOVACUUM PARAMETERS
>>> vacuum full
>>> For me it didn't make any effort.
>>> And I am worried because there is only one feature in postgis table,
>>> nevertheless one redraw from database needs more than 2 minute (I
>>> created
>>> 30
>>> png tiles 256*256 RGB 24bit).
>>> I am afraid I am doing something basically wrong!?
>>> Many thanks in advance for your kind efforts
>>> Susanne Kalliany
>>> Gesendet: Dienstag, 19. August 2008 12:31
>>> Betreff: Re: [mapserver-dev] speed up layer displaying postgis-mapserver
>>> 1. DATA "geom from public.construct >>>>USING UNIQUE [id field name]
>>> USING
>>> SRID=[your srid or -1 (not recom.)]<<<<" for all postgis layers
>>> this solves problem with msPOSTGISLayerRetrievePGVersion
>>> 2. I use cluster gindexname on tablename & vacuum full. +
>>> http://www.powerpostgresql.com/Downloads/annotated_conf_80.html
>>> SUSANNE wrote:
>>>> Dear Mapserver List!
>>>> I am developing Mapserver-application (ms4w 2.2.7, postgres 1.8.2)
>>>> since
>>>> half a year. Now some debugging and optimization work has to be done.
>>>> I am doing quite well with programming, but I am not very experienced
>>>> in
>>>> installation - optimization issues.
>>>> I would be very grateful for some hints to answer the follwing
>>>> questions
>>>> or how to improve performance generally.
>>>> 1. How can I get rid of following error:
>>>> msPOSTGISLayerRetrievePGVersion(): Query error. Error executing POSTGIS
>>>> statement (msPOSTGISLayerRetrievePGVersion():select substring(version()
>>>> from 12 for (position('on' in version()) - 13))
>>>> I did some in internet searches but I could'nt take head or tale of it.
>>>> 2. Should I increase max_buffer in postgresql.conf?
>>>> I found the tip
>>>> (http://mapserver.gis.umn.edu/docs/howto/optimizevector/html2pdf), but
>>>> I
>>>> don't have such an item in my postgres.conf file and also don't know
>>>> which
>>>> value I have to set.
>>>> 3. How to improve displaying of 5 postgres-supported editable layer. It
>>>> takes some time even when these layers are empty!?
>>>> (Installation uses kaMap in javascript-php enviroment)
>>>> thanks a lot, Susanne Kalliany
>>> View this message in context:
> http://www.nabble.com/speed-up-layer-displaying-postgis-mapserver-tp19032703
>>> p19047825.html
>>> Sent from the Mapserver - Dev mailing list archive at Nabble.com.
>>> mapserver-dev mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
>> p19076195.html
> p19087077.html
View this message in context: http://www.nabble.com/speed-up-layer-displaying-postgis-mapserver-tp19032703p19236479.html
