[mapserver-dev] Buildbot down?
Steve Lime
Steve.Lime at dnr.state.mn.us
Mon Dec 1 09:40:12 EST 2008
I recommitted a new version that you used this morning. Tamas also confirmed it
worked on Windows. I created the 5.2.1 release just now and will send notes to
the various lists about it.
Steve
>>> Yewondwossen Assefa <yassefa at dmsolutions.ca> 12/01/08 8:25 AM >>>
Just saw this.
I forgot to specify that my build was done with msvc2007 from svn
(this morning) and does not seem to give me any issues.
Tamas Szekeres wrote:
> 2008/11/29 Steve Lime <Steve.Lime at dnr.state.mn.us
> <mailto:Steve.Lime at dnr.state.mn.us>>
> Ok, no worries. Could someone validate that maplexer.c works for
> them? I had to rebuild on my Mac
> but that's typical. Just want to make sure it works on Linux ok. I
> generated on SuSE 9...
> I've just tried on Windows with MSVC80(x86) and failed. See the output
> below;
> Best regards,
> Tamas
> Microsoft (R) Program Maintenance Utility Version 8.00.50727.762
> Copyright (C) Microsoft Corporation. All rights reserved.
> cl /nologo /Ox /MD /W3 /DDEBUG /EHsc /D_CRT_SECURE_NO_DEPRECATE
> /D_CRT_N
> ONSTDC_NO_DEPRECATE -IE:\builds\release-1400\include
> -IE:\builds\regex-0.12 -DHA
> VE_STRING_H -DREGEX_MALLOC -DNEED_STRCASECMP -DNEED_STRNCASECMP
> -DNEED_STRLCAT -
> DNEED_STRRSTR -DUSE_POSTGIS -DUSE_PROJ -DUSE_PROJ_API_H -DUSE_JPEG
> -DUSE_GD_P
> NG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_GIF -DGD_HAS_GDIMAGEGIFPTR
> -DUSE_GD_FT -
> DGD_HAS_GETBITMAPFONT -DGD_HAS_FTEX_XSHOW -DUSE_OGR -DUSE_WMS_SVR
> -DUSE_THREAD
> -DUSE_WMS_LYR -DUSE_MING_FLASH -DIGNORE_MISSING_DATA
> -DENABLE_STDERR_DEBUG -
> DUSE_GDAL -DUSE_FASTCGI -DUSE_WFS_SVR -DUSE_WFS_LYR -DUSE_WCS_SVR
> -DUSE_GD_A
> NTIALIAS -DUSE_ICONV -DUSE_GEOS -DUSE_ZLIB -DUSE_SOS_SVR
> -DUSE_AGG -DWIN
> 32 -D_WIN32 /c maprgbapng.c /Fomaprgbapng.obj
> maprgbapng.c
> /D_CRT_N
> -DNEED_STRLCAT -
> -DUSE_GD_P
> -DUSE_GD_FT -
> -DUSE_THREAD
> -DUSE_GD_A
> -DUSE_AGG -DWIN
> 32 -D_WIN32 /c mapbits.c /Fomapbits.obj
> mapbits.c
> /D_CRT_N
> -DNEED_STRLCAT -
> -DUSE_GD_P
> -DUSE_GD_FT -
> -DUSE_THREAD
> -DUSE_GD_A
> -DUSE_AGG -DWIN
> 32 -D_WIN32 /c maphash.c /Fomaphash.obj
> maphash.c
> /D_CRT_N
> -DNEED_STRLCAT -
> -DUSE_GD_P
> -DUSE_GD_FT -
> -DUSE_THREAD
> -DUSE_GD_A
> -DUSE_AGG -DWIN
> 32 -D_WIN32 /c mapshape.c /Fomapshape.obj
> mapshape.c
> /D_CRT_N
> -DNEED_STRLCAT -
> -DUSE_GD_P
> -DUSE_GD_FT -
> -DUSE_THREAD
> -DUSE_GD_A
> -DUSE_AGG -DWIN
> 32 -D_WIN32 /c mapxbase.c /Fomapxbase.obj
> mapxbase.c
> /D_CRT_N
> -DNEED_STRLCAT -
> -DUSE_GD_P
> -DUSE_GD_FT -
> -DUSE_THREAD
> -DUSE_GD_A
> -DUSE_AGG -DWIN
> 32 -D_WIN32 /c mapparser.c /Fomapparser.obj
> mapparser.c
> mapparser.c(1753) : warning C4102: 'yyerrlab1' : unreferenced label
> /D_CRT_N
> -DNEED_STRLCAT -
> -DUSE_GD_P
> -DUSE_GD_FT -
> -DUSE_THREAD
> -DUSE_GD_A
> -DUSE_AGG -DWIN
> 32 -D_WIN32 /c maplexer.c /Fomaplexer.obj
> maplexer.c
> maplexer.l(68) : warning C4013: 'msyy_delete_buffer' undefined; assuming
> extern
> returning int
> maplexer.l(71) : warning C4013: 'msyy_scan_string' undefined; assuming
> extern re
> turning int
> maplexer.l(72) : error C2065: 'msyyin' : undeclared identifier
> maplexer.l(72) : warning C4047: '=' : 'int' differs in levels of
> indirection fro
> m 'void *'
> maplexer.l(92) : warning C4047: '=' : 'int' differs in levels of
> indirection fro
> m 'void *'
> maplexer.l(387) : error C2065: 'msyytext' : undeclared identifier
> maplexer.l(388) : warning C4047: 'function' : 'const char *' differs in
> levels o
> f indirection from 'int'
> maplexer.l(388) : warning C4024: 'strlen' : different types for formal
> and actua
> l parameter 1
> maplexer.l(388) : error C2109: subscript requires array or pointer type
> maplexer.l(393) : warning C4047: 'function' : 'const char *' differs in
> levels o
> maplexer.l(393) : warning C4024: 'strlen' : different types for formal
> and actua
> l parameter 1
> maplexer.l(393) : error C2109: subscript requires array or pointer type
> maplexer.l(394) : warning C4047: 'function' : 'const char *' differs in
> levels o
> maplexer.l(394) : warning C4024: 'atof' : different types for formal and
> actual
> parameter 1
> maplexer.l(400) : warning C4047: 'function' : 'const char *' differs in
> levels o
> maplexer.l(400) : warning C4024: 'strlen' : different types for formal
> and actua
> l parameter 1
> maplexer.l(400) : error C2109: subscript requires array or pointer type
> maplexer.l(405) : warning C4047: 'function' : 'const char *' differs in
> levels o
> maplexer.l(405) : warning C4024: 'atof' : different types for formal and
> actual
> parameter 1
> maplexer.l(410) : warning C4047: 'function' : 'const char *' differs in
> levels o
> maplexer.l(410) : warning C4024: 'atof' : different types for formal and
> actual
> parameter 1
> maplexer.l(416) : warning C4047: 'function' : 'const char *' differs in
> levels o
> maplexer.l(416) : warning C4024: 'strlen' : different types for formal
> and actua
> l parameter 1
> maplexer.l(416) : error C2109: subscript requires array or pointer type
> maplexer.l(418) : warning C4047: 'function' : 'const char *' differs in
> levels o
> maplexer.l(418) : warning C4024: 'msParseTime' : different types for
> formal and
> actual parameter 1
> maplexer.l(425) : warning C4047: 'function' : 'const char *' differs in
> levels o
> maplexer.l(425) : warning C4024: 'strlen' : different types for formal
> and actua
> l parameter 1
> maplexer.l(425) : error C2109: subscript requires array or pointer type
> maplexer.l(431) : warning C4047: 'function' : 'const char *' differs in
> levels o
> maplexer.l(431) : warning C4024: 'strlen' : different types for formal
> and actua
> l parameter 1
> maplexer.l(431) : error C2109: subscript requires array or pointer type
> maplexer.l(432) : warning C4047: 'function' : 'const char *' differs in
> levels o
> maplexer.l(432) : warning C4024: 'strdup' : different types for formal
> and actua
> l parameter 1
> maplexer.l(439) : warning C4047: 'function' : 'const char *' differs in
> levels o
> maplexer.l(439) : warning C4024: 'strlen' : different types for formal
> and actua
> l parameter 1
> maplexer.l(439) : error C2109: subscript requires array or pointer type
> maplexer.l(445) : warning C4047: 'function' : 'const char *' differs in
> levels o
> maplexer.l(445) : warning C4024: 'strlen' : different types for formal
> and actua
> l parameter 1
> maplexer.l(445) : error C2109: subscript requires array or pointer type
> maplexer.l(446) : warning C4047: 'function' : 'const char *' differs in
> levels o
> maplexer.l(446) : warning C4024: 'strdup' : different types for formal
> and actua
> l parameter 1
> maplexer.l(453) : warning C4047: 'function' : 'const char *' differs in
> levels o
> maplexer.l(453) : warning C4024: 'strlen' : different types for formal
> and actua
> l parameter 1
> maplexer.l(453) : error C2109: subscript requires array or pointer type
> maplexer.l(459) : warning C4047: 'function' : 'const char *' differs in
> levels o
> maplexer.l(459) : warning C4024: 'strlen' : different types for formal
> and actua
> l parameter 1
> maplexer.l(459) : error C2109: subscript requires array or pointer type
> maplexer.l(465) : warning C4047: 'function' : 'const char *' differs in
> levels o
> maplexer.l(465) : warning C4024: 'strlen' : different types for formal
> and actua
> l parameter 1
> maplexer.l(465) : error C2109: subscript requires array or pointer type
> maplexer.l(474) : warning C4047: 'function' : 'const char *' differs in
> levels o
> maplexer.l(474) : warning C4024: 'msBuildPath' : different types for
> formal and
> actual parameter 3
> maplexer.l(474) : warning C4047: '=' : 'int' differs in levels of
> indirection fr
> om 'FILE *'
> maplexer.l(480) : warning C4013: 'msyy_switch_to_buffer' undefined;
> assuming ext
> ern returning int
> maplexer.l(480) : warning C4013: 'msyy_create_buffer' undefined;
> assuming extern
> returning int
> maplexer.l(487) : warning C4047: 'function' : 'const char *' differs in
> levels o
> maplexer.l(487) : warning C4024: 'strlen' : different types for formal
> and actua
> l parameter 1
> maplexer.l(487) : error C2109: subscript requires array or pointer type
> maplexer.l(493) : warning C4047: 'function' : 'const char *' differs in
> levels o
> maplexer.l(493) : warning C4024: 'strlen' : different types for formal
> and actua
> l parameter 1
> maplexer.l(493) : error C2109: subscript requires array or pointer type
> maplexer.l(495) : warning C4047: '=' : 'char *' differs in levels of
> indirection
> from 'int'
> maplexer.l(511) : error C2109: subscript requires array or pointer type
> maplexer.l(528) : warning C4047: 'initializing' : 'char *' differs in
> levels of
> maplexer.l(560) : error C2109: subscript requires array or pointer type
> maplexer.l(560) : warning C4033: 'yylex' must return a value
> NMAKE : fatal error U1077: '"C:\Program Files (x86)\Microsoft Visual
> Studio 8\VC
> \BIN\cl.EXE"' : return code '0x2'
> Stop.
> Studio 8\VC
> \BIN\nmake.EXE"' : return code '0x2'
> Stop.
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
