[mapserver-dev] call for vote on rfc 48
thomas bonfort
thomas.bonfort at gmail.com
Thu Dec 4 15:09:25 EST 2008
On Thu, Dec 4, 2008 at 21:03, Daniel Morissette
<dmorissette at mapgears.com> wrote:
> thomas bonfort wrote:
>> the square brackets are required, as they denote an argument that
>> depends on the data query. The aim would be to stay consistent if some
>> day we have something like buffer([geom],[distance]).
> Well, then the examples in the RFC need to be fixed since they don't have
> square brackets.
hmm, yes I see I missed some out. will correct.
>> I agree that the
>> notation is a bit awkward as "geom" has no linkage with the actual
>> data request.
> You had suggested in the previous RFC-48 thread that the square brackets
> could collide with the attribute binding syntax and proposed taking them
> away... and I agreed with that.
Steve was against that:
- syntax should use [geom] instead of plain geom in keeping with
expression syntax
I have no preference over one or the other.
