[mapserver-dev] Map Symbol Idea (IF .. THEN)
Steve Lime
Steve.Lime at dnr.state.mn.us
Mon Dec 29 12:18:23 EST 2008
Bob: Are you referring to swapping SYMBOLSET's? You could have multiple versions that share
naming conventions and swap between those on-the-fly. That may actually be possible now.
Steve
>>> On 12/29/2008 at 11:07 AM, in message <4958AF5A020000A80000FA9E at jeckle>, "Bob
Basques" <Bob.Basques at ci.stpaul.mn.us> wrote:
> All,
> Just had a thought about all the map symbol discussions going on.
> I've recently had to work on some emergency management planning teams. In
> order to get a system in place that has a chance to work for everyone (across
> borders), there are certain symbol sets that have some measure of a following
> at the national and some professional levels for emergency management
> operations.
> Now, in order to get a system in place that people use on a day to day basis
> (which is the best way to train folks in their use), there needs to be ( I
> think) a way to change symbology on the fly (so to speak).
> Now to the "idea", what are peoples thoughts on having a IF/THEN clause in
> the MapServer rendering Stream that allows for swapping out Symbols at the
> request level? I know some of this can be handled with SLDs, but that's
> somewhat limited IMO. My first thought is to have a set of
> (possible/optional) alternate symbols that can be used in place of some
> existing symbols already in use in the day to day operations. The idea being
> to switch the interface over to a standardized emergency management mode of
> operation at the user level. The local users would still be able to view the
> map via their historical symbol set, while any outside users (other
> jurisdictions), could still come into the system and use the system in a
> standardized manner. I'm only bringing up the emergency management aspects,
> but I'm sure there are other potential uses/application of the capability.
> I guess a shorter question would be, how to build into MapServer, support
> for multiple symbols (per data set)?
> I have some ideas about using a similar capability for general GUI
> improvements as well, but I'll let those go for now.
> This may be best handled outside of the MapServer development ranks, but I
> figured I would ask anyway.
> Thanks
> bobb
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
