[mapserver-dev] Re: [mapserver-users] Image not rendered on large
	monitors.
    thomas bonfort
    thomas.bonfort at gmail.com
    Tue Dec 30 05:47:31 EST 2008
hi,
set maxsize to something bigger, eg 4096
regards,
thomas
On Tue, Dec 30, 2008 at 11:45, Subha Ramakrishnan <subha at gslab.com> wrote:
> Hi,
> We have built a map based web portal using Openlayers and Mapserver 5.0.2.
> We have multiple layers being rendered using Mapserver.
> But we are facing an issue here.
> On large monitors  with the resolutions, "1680 x 1050", "1856 x 1392" ,"1920
> x 1080"(21 inches and above), mapserver doesn't render images.
> It throws an error saying "WMS server error.Image size out of range,Width
> and height must be between 1 and 2048 pixels."
> I have tried setting the "MAXSIZE" as 2048 in my map file but it doesn't
> seem to work.
> My mapfile is as follows:
> map
>  size 725 800
>  imagetype png
>  imagecolor 225 225 225
>  projection
>   "init=epsg:4326"
>  end
>  extent 60 0 100 40
>  maxsize 2048
> outputformat
>   name "jpg"
>   driver "GD/JPEG"
>   extension "jpg"
>   formatoption "QUALITY=85"
>  end
> layer
>  name xyz
>  connectiontype postgis
>  connection "user= abc dbname=qwe password=fgg host=localhost"
>  group world
>  type polygon
>  status on
>  data "topology from table"
>  class
>   style
>     width 3
>   outlinecolor 000 000 255
>   end
>  end
>  end
> end
> Is there something wrong that in the mapfile? Or if there is any other
> solution that someone knows, please let me know.
> Thanks for the help.
> Regards,
> Subha
> mapserver-users at lists.osgeo.org
