No subject
Fri Feb 8 14:55:41 EST 2008
in "3.6 Always give object ownership to SWIG"
2. You've suggested to keep references to the parent objects at the
target language. How would you implement this?
How many code changes would be needed? Would this implementation be
mapscript specific, or you could propose some type independent
solution like using a number of "typemap() SWIGTYPE" for example?
I will attach an UML diagram to describe the current parent-child
relationships. We can see that some of the objects (like rectObj)
belongs to various class types.
I think it would be fairly complicated to implement these changes for
the mapscript specific classes one by one. Would these changes
eliminate the need of using refcounts at the C side?
I will also attach a C# specific typeless implementation for the same
problem (taken out of the current gdal C# project)
3. How the original concept of the object ownership is altered by this
RFC. Who is responsible to create and finally remove a particular
object? The C refcount implementation impresses that those objects are
self owned (controlled by the refcounts), but the comments at 3.2
shows that the original concept should be retained (So that finally
the child should be controlled by the parent).
4. I consider the decrementation of the refcount cannot be used solely
without controlling the destruction of that item like in layerObj
*msRemoveLayer(mapObj *map, int nIndex). What to do if the refcount
reaches zero in this case?
5. Not only the layerObj and classObj collection arrays should be
handled. This proposal should deal with the replacement of the other
collection arrays like styleObj and symbolObj arrays respectively.
Best regards,
Tamas
2007/3/13, Umberto Nicoletti <umberto.nicoletti at gmail.com>:
> I've put some more effort in preparing a demo of how rfc-24 would be
> implemented.
> I've attached a new patch to
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=2032
> that implements:
> 1. classes as array of pointers
> 2. dynamic classes
> 3. reference counting for most classes operations (see the python test
> case for what's been done)
> 4. more python unit tests to cover the new class code
> 5. fixed some memory leaks (some introduced by the previous patches,
> some already there)
> Apply the new patch 636 after 632 and 633 to mapserver head (inside
> the mapserver directory):
> patch -l -p0 < 632.patch
> patch -l -p0 < 633.patch
> patch -l -p1 < this.patch
> Note the -p1 switch on the last patch command. Last patch will
> complain about maplayer.c, please answer as follows:
> assume reverse: n
> apply anyway: y
> You can safely ignore errors for now as they're only comments or indentation.
> There's a lot of activity going on on cvs in these days so it could be
> that in the next the few days it will be more difficult to apply the
> patches.
> At this point I think there is enough code to look at to plan the
> opening of a voting thread on rfc-24 at the end of next week (around
> March 23). If your schedule is too busy I can consider delaying the
> voting session of course.
> Best regards,
> Umberto
> On 3/4/07, Umberto Nicoletti <umberto.nicoletti at gmail.com> wrote:
> > I have been working on an example implementation of rfc-24 and the
> > fruit of my labor is attachment #632 to:
> > Direct link:
> > http://mapserver.gis.umn.edu/bugs/attachment.cgi?id=632&action=view
> > Apply this patch to cvs HEAD to see how rfc24 would be implemented.
> > The patch only modifies the map and layer objects, the rest is still unmodified.
> > Key points:
> > 1. refactor map->layers to be an array of pointers instead of a array of structs
> > 2. allocation of a new layerObj only happens when needed, thus conserving memory
> > (allowing for large values of MAX_NUM_LAYERS with minimal waste of memory)
> > 3. wrap map->layers access with GET_LAYER macros to ease future developments
> > (i.e. removal of MAX_NUM_LAYERS)
> > 4. check that layer->map is not null before using it and raise a new
> > error if it is (MS_NULLPARENTERR)
> > 5. reference counter for mapObj and layerObj
> > 6. modification of mapserver core and swig interface files to do reference
> > counting for map and layers (incr and decr)
> > 7. created unit tests for python (mapscript/python/tests/cases/refcount.py) to
> > test the functionality of the previous items. This has not been added to
> > runtests.py yet
> > Due to the large extent of the changes I have also made available
> > items 1,2,3 and item 4 available as two separate patches.
> > Happy hacking and tell me what you think,
> > Umberto
------=_Part_68625_32644807.1173989606058
Content-Type: text/plain; name=swig_csharp_extensions.i;
charset=ANSI_X3.4-1968
Content-Transfer-Encoding: base64
X-Attachment-Id: f_ezbmv51t
Content-Disposition: attachment; filename="swig_csharp_extensions.i"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Content-Type: application/pdf; name=mapscript.pdf
X-Attachment-Id: f_ezbmvj0h
Content-Disposition: attachment; filename="mapscript.pdf"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==
------=_Part_68625_32644807.1173989606058--
