transparency bug in GetLegendGraphic
Bart van den Eijnden
bartvde at GMAIL.COM
Thu Feb 7 08:36:29 EST 2008
I've opened up a bug and attached a patch (I love those single-line
problems, at least I can fix those :-) ):
http://trac.osgeo.org/mapserver/ticket/2494
Best regards,
Bart
On Feb 6, 2008 11:59 AM, Bart van den Eijnden <bartvde at gmail.com> wrote:
> Hi list,
> it seems an image returned by WMS GetLegendGraphic can't be made
> transparent unless we use the deprecated TRANSPARENT property of the LEGEND
> object.
> My outputformat is defined transparent:
> OUTPUTFORMAT
> NAME "png"
> MIMETYPE "image/png"
> DRIVER "GD/PNG"
> EXTENSION "png"
> IMAGEMODE "RGBA"
> TRANSPARENT TRUE
> END
> If I try an equivalent mode=legend request the legend does come back
> transparent, so I believe this is likely a problem in the mapwms.c code.
> This is both a problem in MS 5.0 and 4.8.4.
> Any pointers?
> Example page to reproduce:
> <html>
> <body style="background-color:#FF0000">
> <img src="
> http://www.rijkswaterstaat.nl/services/geoservices/basispakket/grenzen?mode=legend&layer=AAA212
> <img src="
> http://www.rijkswaterstaat.nl/services/geoservices/basispakket/grenzen?service=WMS&format=image/png&request=GetLegendGraphic&version=1.1.1&layer=AAA212
> </body>
> </html>
> Best regards,
> Bart
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20080207/83e96437/attachment.html
