Standardized source header
Normand Savard
nsavard at MAPGEARS.COM
Thu Feb 7 10:17:50 EST 2008
I propose to not change the following files header: mapparser.c
(below), mapparser.h and mapparser.y. They have their own license.
What do you think?
Norm
mapparser.c:
/* A Bison parser, made by GNU Bison 1.875. */
/* Skeleton parser for Yacc-like parsing with Bison,
Copyright (C) 1984, 1989, 1990, 2000, 2001, 2002 Free Software
Foundation, Inc.
This program is free software; you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation; either version 2, or (at your option)
any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program; if not, write to the Free Software
Foundation, Inc., 59 Temple Place - Suite 330,
Boston, MA 02111-1307, USA. */
/* As a special exception, when this file is copied by Bison into a
Bison output file, you may use that output file without restriction.
This special exception was added by the Free Software Foundation
in version 1.24 of Bison. */
/* Written by Richard Stallman by simplifying the original so called
``semantic'' parser. */
/* All symbols defined below should begin with yy or YY, to avoid
infringing on user name space. This should be done even for local
variables, as they might otherwise be expanded by user macros.
There are some unavoidable exceptions within include files to
define necessary library symbols; they are noted "INFRINGES ON
USER NAME SPACE" below. */
mapparser.h:
Foundation, Inc.
any later version.
mapparser.y:
** Parser for the mapserver
