[MAPSERVER-DEV] Standardized source header
Arnulf Christl (OSGeo) arnulf.christl at wheregroup.com
Mon Feb 11 12:56:13 EST 2008
Steve,
the difference between the two licenses can be seen here:
http://wiki.osgeo.org/index.php?title=MapServer_Provenance_Review&diff=22575&oldid=22574
The relevant bit is:
MIT:
"all copies or substantial portions of the Software."
MapServer:
"all copies of this Software or works derived from this Software."
I don't see a real problem but I would still suggest that while you are at
it you might want to decide to change your standard header for the OSI
certified one.
Regards,
Arnulf.
>>>> Arnulf Christl <arnulf.christl at wheregroup.com> 02/08/08 2:44 AM >>>
> Steve Lime wrote:
>> I don't see how OSI certification impacts this at all. I believe that,
>> way back, Tom Burk submitted the  MapServer  license to them for
>> approval but never received a response...
One of the common goals of FSF and OSI is to prevent proliferation of
licenses. OSGeo says this about licensing (maybe this needs to be changed
a bit):
http://www.osgeo.org/content/foundation/about.html
"The foundation's projects are all freely available and useable under an
OSI-certified open source license." Open Source Initiative (tm) Logo
But on the Open Source org page it says: The logo "Open Source Initiative
(tm)" may only be used by projects that use one of the approved licenses.
Search this page for logo to read about usage:
http://opensource.org/faq
I should have noticed this earlier. This has probably no relevance as long
as OSGeo is not the Copyright owner. On the other hand OSGeo wants to be a
common roof and wears the OSI trademark on the web. Any comments?
Regards, Arnulf.
Arnulf Benno Christl
(OSGeo Board Member)
+50.7342N   +7.0707E
