[mapserver-dev] Point layers with Oracle driver
Daniel Morissette dmorissette at mapgears.com
Tue Feb 12 11:05:51 EST 2008
Fernando,
I've had someone report to me that when MapServer reads point layers
from Oracle, it works fine if the coordinates are stored in the
SDO_POINT, but it doesn't work if they are stored in SDO_ELEM_INFO or
SDO_ORDINATES which are apparently two other valid ways of storing point
data.
Are you aware of this issue? Is there a way around it or do you have any
advice to provide to users who run into this problem?
Thanks
Daniel
Daniel Morissette
http://www.mapgears.com/
