[mapserver-dev] mapsde : qualified names vs non qualified names
Yewondwossen Assefa
yassefa at dmsolutions.ca
Wed Feb 20 18:55:59 EST 2008
Hi There,
Working with mapserver/sde layers, we came across an issue where the
attribute names used (ex for a querybyattributes) must be qualified if
there is a Join done on the layer and non-qualified if there is no join.
Note that this is documented.
Do you see any advantage/problem to always be able to use qualified
names either there is a join or not? At least be able for those who want
it, to be able to have a setting so that qualified names are always
used. (this would preserve the way it works now if there is nothing set)
Thanks
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
