Antwort: Re: [mapserver-dev] Point layers with Oracle driver
Daniel Morissette dmorissette at mapgears.com
Wed Feb 27 16:16:11 EST 2008
Fernando Simon wrote:
> Citando Daniel Morissette <dmorissette at mapgears.com>:
>> Fernando, would you consider adding support for reading the
>> SDO_ORDINATES value when SDO_POINT is null since that seems to be a
>> valid case according to this page?
> http://download-west.oracle.com/docs/cd/B19306_01/appdev.102/b14255/sdo_objrelschema.htm#CBBIGEFH
>> I can create a ticket for that if you want...
> Daniel,
>     Yes, I will add the support for this kind of point. I belive that
> the ticket is the best way, we can track/log all the info about it.
> No problem, you can open the ticket.
It took me a little while, but here is the ticket:
   http://trac.osgeo.org/mapserver/ticket/2530
Thanks
Daniel
Daniel Morissette
http://www.mapgears.com/
