WMS GetFeatureInfo and
Frank Warmerdam
warmerdam at POBOX.COM
Tue Jan 22 23:26:47 EST 2008
Folks,
I have discovered my previous improvement to error handling when
attempting to draw query maps for raster query results has resulted
in WMS GetFeatureInfo breaking on raster layers.
The msautotest/wxs/tomk_workshop.map map has a test request like this:
# Generate WMS GetFeatureInfo GML format on vector data
# RUN_PARMS: wms_get_feature_info_vector.gml [MAPSERV]
QUERY_STRING="map=[MAPFILE]&version=1.1.1&service=WMS&request=GetFeatureInfo
&srs=EPSG:4326&bbox=-180,-90,180,90&format=image/png
&layers=land_shallow_topo_2048,rivers&styles=,&transparent=true&width=500
&height=300&query_layers=rivers&info_format=application/vnd.ogc.gml
&x=141&y=91&radius=10" > [RESULT]
When working properly, this test results in an HTML result for the
query against the raster layer. However, since my 'fix' for
http://trac.osgeo.org/mapserver/ticket/1842 this now fails with a
report about trying to draw a raster query layer.
The tracback looks something like:
(gdb) where
#0 msDrawQueryLayer (map=0x7959d0, layer=0x7ab9d0, image=0x7b4130) at
mapdraw.c:949
#1 0x00000000004682eb in msDrawMap (map=0x7959d0, querymap=1) at mapdraw.c:431
#2 0x00000000004182de in msReturnTemplateQuery (msObj=0x7b4af0,
pszMimeType=0x7ab430 "text/html", papszBuffer=0x0) at maptemplate.c:200
#3 0x0000000000538d3e in msWMSFeatureInfo (map=0x7959d0, nVersion=65793,
names=0x794690, values=0x7949c0, numentries=23) at mapwms.c:2442
#4 0x000000000053a961 in msWMSDispatch (map=0x7959d0, req=0x794660) at
mapwms.c:3054
#5 0x00000000004c6b53 in msOWSDispatch (map=0x7959d0, request=0x794660) at
mapows.c:60
#6 0x0000000000412f18 in main (argc=2, argv=0x7fffb57b06d8) at mapserv.c:1147
The question I have is, why does a WMS GetFeatureInfo request for an html
template generated response result in MapServer drawing a query result
as an image? It seems that the image is saved to a temp file, and never
actually used.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
