MapServer 5.0.2 released
Daniel Morissette
dmorissette at MAPGEARS.COM
Mon Jan 28 11:14:54 EST 2008
MapServer 5.0.2 has just been released. This new release solves a build
problem that was reported with v5.0.1 released last week. It does not
contain any other bug fix or new feature. If you were able to build
MapServer 5.0.1 on your system then you probably do not need to upgrade.
Otherwise if you encountered build problems related to maplexer.c with
MapServer 5.0.1 last week then this 5.0.2 release is for you.
The source package is available in the MapServer downloads page:
http://mapserver.gis.umn.edu/download/current/
Precompiled binaries should be available shortly at the usual locations
(also linked from the download page above).
Daniel
