[mapserver-dev] get area between points with latlong info to make a
map
S.Reena
reena at indiamail.com
Tue Jul 1 02:26:17 EDT 2008
I have a postgres table which I want to represent in map...the attributes
being ( the_geom, name, latlon etc..) I want to calculate the area of all
the points (using the_geom) having name LIKE ' ABC' ...[A single tuple
having the_geom , area and name field is required ) so that I can represent
it using a polygon in map.
How to do that.......
S.Reena
View this message in context: http://www.nabble.com/get-area-between-points-with-latlong-info-to-make-a-map-tp18210024p18210024.html
Sent from the Mapserver - Dev mailing list archive at Nabble.com.
