[mapserver-dev] MapServer 5.2 Release Candidate 1 Available
Steve Lime
Steve.Lime at dnr.state.mn.us
Wed Jul 9 22:37:34 EDT 2008
Hi folks: MapServer 5.2 RC 1 has just been released. The source package is available for download at:
http://mapserver.gis.umn.edu/download/beta
The list of changes/fixes since 5.0 can be found at the end this message. This is a significant release so
we need your help in testing. 5.2 should compatible with any 5.0 applications/mapfiles so it should be
relatively easy for folks to test. Please let us know how it goes!
This is the 1st, and perhaps only, release candidate (we hope) and if all goes well the final release will be next week.
More details can be found in the 5.2 release plan at:
http://mapserver.gis.umn.edu/development/release_plans/mapserver_5_2/release_plan/
Steve
Version 5.2.0-rc1 (2008-07-09):
- mapowscommon.c: fix support multiple namespaces (#2690)
- Fix OGC simple filters on SDE layers (#2685)
- wfs11 getcapabilities: correct memory corruption (#2686)
- Allow building against Curl 7.10.6 and older which lack CURLOPT_PROXYAUTH
option required for *_proxy_auth_type metadata (#571)
- Avoid fatal error when creating new ShapeFileObj with MapScript (#2674)
- Fixed problem with WMS INIMAGE exceptions vs AGG output formats (#2438)
- mapshape.c: Fixed integer pointer math being applied to uchars (#2667)
- Fixed seg fault with saveImage() in PHP MapScript due to #2673 (#2677)
- Fixed configure error related to new fribidi2 pkg-config support (#2664)
- Fixed windows build problem (#2676)
- Fix raster query bounds problem (#2679)
