[mapserver-dev] A buffer overflow in maporaclespatial
Albert Rovira
arovira at ngeografics.com
Thu Jul 10 10:29:50 EDT 2008
Hello,
I get a core dump when I using this layer definition:
LAYER
CLASSITEM "vu_id"
CONNECTION "cerc/cerc at cerc"
CONNECTIONTYPE ORACLESPATIAL
DATA "SHAPE from (select id,shape,vu_id from cercalia.LOIS_MAPA
where (categoria_id = '9CQRUT' and tipo_id = '039') or (categoria_id =
'9CQRUT' and tipo_id = '069') or (categoria_id = '9CQRUT' and tipo_id =
'004') or (categoria_id = '9CQRUT' and tipo_id = '005') or (categoria_id
= '9CQRUT' and tipo_id = '066') or (categoria_id = '9CQRUT' and tipo_id
= '047') or (categoria_id = '9CQRUT' and tipo_id = '078') or ...
**** BANDWITDH SAVER **** ;-)
... (categoria_id = '9CQRUT' and tipo_id = '076') or (categoria_id =
'9CQRUT' and tipo_id = '008') or (categoria_id = '9CQRUT' and tipo_id =
'007') or (categoria_id = '9CQRUT' and tipo_id = '052') or (categoria_id
= '9CQRUT' and tipo_id = '019') or (categoria_id = '9CQRUT' and tipo_id
= '020') or (categoria_id = '9CQRUT' and tipo_id = '011') or
(categoria_id = '9CQRUT' and tipo_id = '029')) using srid 558000"
DEBUG ON
DUMP TRUE
METADATA
END
NAME "lois"
SIZEUNITS PIXELS
STATUS ON
TOLERANCEUNITS PIXELS
TYPE LINE
UNITS METERS
CLASS
EXPRESSION /4560/
METADATA
END
STYLE
ANGLE 360
OUTLINECOLOR 250 220 0
SIZE 4
SYMBOL 8
END
END
CLASS
EXPRESSION /4561/
METADATA
END
STYLE
ANGLE 360
SIZE 4
SYMBOL 8
END
END
CLASS
EXPRESSION /4562/
METADATA
END
STYLE
ANGLE 360
SIZE 4
SYMBOL 8
END
END
END
After dig a bit in mapOracleSpatial.c, I see that table_name array is
too small to hold the select string that is about 3200 bytes.
Line 1628 in mapOracleSpatial.c:
/* create SQL statement for retrieving shapes */
int msOracleSpatialLayerWhichShapes( layerObj *layer, rectObj rect )
int success, i;
int function = 0;
int version = 0;
char query_str[6000];
char table_name[2000], geom_column_name[100], unique[100], srid[100];
Can Mapserver team modify it to use dinamic strings ? If not, can
Mapserver team make this array bigger ? It's a bit annoying must
recompile mapserver only for this little bug.
Thanks,
Albert.
