[mapserver-dev] 5.2rc1: GetLegendGraphic change?
Yewondwossen Assefa yassefa at dmsolutions.ca
Fri Jul 11 10:22:18 EDT 2008
Bart,
   I am not sure why would get this behavior since effectively STYLE is
an optional parameter.  Looking into the code, It seems that the error
message reported could only happen if STYLE is defined.
I have done local tests on windows/linux (using the same wms parameters
as your example) with MapServer svn and I get the expected result.
Could you send me a simple sample that I can look at? I think if there
is an issue we should address it before the 5.2 release.
Best Regards,
bartvde at osgis.nl wrote:
> Hi list,
> using 5.2rc1, something changed, my GetLegendGraphic requests are not
> working anymore.
> A request like:
> http://test.intranet.rijkswaterstaat.nl/services/geoservices/basispakket/nationaalwegenbestand?service=WMS&format=image/png&request=GetLegendGraphic&version=1.1.1&layer=AAA62
> yields now an exception:
> <?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
> <!DOCTYPE ServiceExceptionReport SYSTEM
> "http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd">
> <ServiceExceptionReport version="1.1.1">
> <ServiceException code="StyleNotDefined">
> msWMSGetLegendGraphic(): WMS server error. style used in the STYLE
> parameter is not defined on the layer.
> </ServiceException>
> </ServiceExceptionReport>
> Which I don't get since STYLE is an optional parameter.
> Did something break?
> Best regards,
> Bart
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
