[mapserver-dev] 5.2.0 memory leaks?
Steve Lime
Steve.Lime at dnr.state.mn.us
Mon Jul 14 10:43:31 EDT 2008
Have run against 5.0? If they're there in that version too then I'm not worried about
this for this release. My guess is that these are not new leaks.
Steve
>>> On 7/13/2008 at 12:13 AM, in message <48798F14.1070801 at swoodbridge.com>,
Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
> Steve L,
> I have been playing around with a test program to generate some images.
> It was some mapscript that I wanted to see if I could get working as a C
> program calling the mapserver library calls.
> This run was based on mapserver-5.2.0-beta2 and it looks like we have
> some memory leaks in the mapserver code. It is also possible that I
> mis-used the library, but these seem to be pretty deep in mapserver and
> I'm not trying to do anything fancy.
> I'll check the same run against RC1, but I guess my generic question is
> how much check has been done with valgrind. This run only generates two
> images, but if I wanted to generate lots more this could be serious. In
> fact, I think I've seen php/mapscript precache2.php run into a leak
> where the process kept growing and finally died and had to be restarted.
> -Steve
> ==5821== ERROR SUMMARY: 0 errors from 0 contexts (suppressed: 3 from 1)
> ==5821== malloc/free: in use at exit: 7,724 bytes in 29 blocks.
> ==5821== malloc/free: 337,243 allocs, 337,214 frees, 121,668,226 bytes
> allocated.
> ==5821== For counts of detected errors, rerun with: -v
> ==5821== searching for pointers to 29 not-freed blocks.
> ==5821== checked 15,450,752 bytes.
> ==5821==
> ==5821== 24 bytes in 3 blocks are definitely lost in loss record 5 of 15
> ==5821== at 0x4A18DA3: malloc (vg_replace_malloc.c:149)
> ==5821== by 0x4276A1: msLayerWhichItems (maplayer.c:440)
> ==5821== by 0x42A20D: msDrawVectorLayer (mapdraw.c:841)
> ==5821== by 0x429E44: msDrawLayer (mapdraw.c:738)
> ==5821== by 0x429A73: msDrawMap (mapdraw.c:441)
> ==5821== by 0x40E67E: main (genimages.c:1112)
> ==5821==
> ==5821==
> ==5821== 24 bytes in 4 blocks are definitely lost in loss record 6 of 15
> ==5821== by 0x4B35D78: gdMalloc (in /usr/lib/libgd.so.2.0.33)
> ==5821== by 0x4B33830: (within /usr/lib/libgd.so.2.0.33)
> ==5821== by 0x4B336DB: gdImageCreatePaletteFromTrueColor (in
> ==5821== by 0x43ACED: msImageCreateWithPaletteGD (mapgd.c:3441)
> ==5821== by 0x43B022: msSaveImageGDCtx (mapgd.c:3576)
> ==5821== by 0x43AE2F: msSaveImageGD (mapgd.c:3495)
> ==5821== by 0x4437A8: msSaveImageAGG (mapagg.cpp:2216)
> ==5821== by 0x41ACB4: msSaveImage (maputil.c:657)
> ==5821== by 0x40E6B4: main (genimages.c:1120)
> ==5821==
> ==5821==
> ==5821== 66 (48 direct, 18 indirect) bytes in 3 blocks are definitely
> lost in loss record 11 of 15
> ==5821== at 0x4A1A362: calloc (vg_replace_malloc.c:279)
> ==5821== by 0x427680: msLayerWhichItems (maplayer.c:435)
> ==5821==
> ==5821== LEAK SUMMARY:
> ==5821== definitely lost: 96 bytes in 10 blocks.
> ==5821== indirectly lost: 18 bytes in 3 blocks.
> ==5821== possibly lost: 0 bytes in 0 blocks.
> ==5821== still reachable: 7,610 bytes in 16 blocks.
> ==5821== suppressed: 0 bytes in 0 blocks.
> ==5821== Reachable blocks (those to which a pointer was found) are not
> shown.
> ==5821== To see them, rerun with: --show-reachable=yes
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
