[mapserver-dev] MapServer 5.0.3 released
Daniel Morissette
dmorissette at mapgears.com
Wed Jun 4 16:17:39 EDT 2008
MapServer 5.0.3 has just been released. This new release addresses a few
issues that were fixed since version 5.0.2 and contains no new
functionality. The list of fixes since 5.0.2 is included at the end of
this message, the full change log can also be browsed online at
http://mapserver.gis.umn.edu/download/current/HISTORY.TXT
The source package is available in the MapServer downloads page:
Precompiled binaries should be available shortly at the usual locations
(also linked from the download page above).
Daniel
Version 5.0.3 (2008-06-04)
- Exposed ERROR and EMPTY webObj properties to URL-based configuration.
(#2634)
- Avoid displaying OGR connection strings in error messages (#2629)
- mappostgis.c: fix postgis idle-in-transaction problem (#2626)
- mapogcsld.c: fetch TextSymbolizer/Label/ogc:PropertyName correctly
(#2611)
- Don't ignore .qix file when DATA reference includes .shp extension (#590)
- CGI able to alter layers with space and underscores (#2516)
- WFS Multipoint query with PostGIS bug fixed (#2443)
- mappostgis.c: Fixed overlapping transactions causing core
dump in fcgi (#2497, #2613)
- mapagg.cpp: Fixed rendering of non filled vector symbols (#2585)
- Fixed handling of encrypted connection strings in postgis driver (#2563)
- Fixed problem with large imagemaps generating no output (#2526)
- Fixed problem with two division signs in an expression being treated
as a regex (#2527)
- Fixed gdImagePtr gdPImg memory leak in msSaveImageBufferGD() (#2525)
- mapwms.c: relax FORMAT parameter restrictions for GetFeatureInfo (#2517)
- mapwms.c: make GetLegendGraphic listen to TRANSPARENT in OUTPUTFORMAT
(#2494)
- fix offsets on pixmap marker symbols (#2493)
- fix segfault in mapserv if STYLE is not defined (#2347)
