[mapserver-dev] getting a crash that might be 32-64 bit ro
buildissue related
Stephen Woodbridge
woodbri at swoodbridge.com
Sat Jun 21 12:44:50 EDT 2008
Here is the stacktrace from gdb on 5.2 beta2. As I said before, this
does not segv at least I did not wait that long to see and I have let it
run for 5+mins in the past with it using 100% cpu. The numbers for x1
and x2 in the call to imageScanline() look suspect, but I'm not familiar
with this code.
(gdb) bt
#0 imageScanline (im=0x1a168400, x1=-16480499, x2=0, y=-2147483648,
c=2467402)
at mapgd.c:678
#1 0x00000000004426ea in imageFilledPolygon (im=0x1a168400,
p=0x7fff290ad2e0,
c=2467402, offsetx=0, offsety=0) at mapgd.c:975
#2 0x000000000044d06b in msDrawShadeSymbolGD (symbolset=0x19ee6230,
img=0x1a168400, p=0x7fff290ad2e0, style=0x7fff290ad1d0, scalefactor=1)
at mapgd.c:2258
#3 0x000000000043c749 in msDrawLabelCache (image=0x19eefd90,
map=0x19ee6200)
at mapdraw.c:2215
#4 0x0000000000441157 in msDrawMap (map=0x19ee6200, querymap=0)
at mapdraw.c:490
#5 0x000000000040bdcc in main (argc=1, argv=<value optimized out>)
at mapserv.c:1405
-Steve
thomas bonfort wrote:
> Hi,
> could you also include the stacktrace from 5.2 please.
> it seems the segfault appears when using a backgroundcolor for the
> label. Would it be easy for you to try to disable them and confirm?
> thanks,
> thomas
> On Sat, Jun 21, 2008 at 6:17 AM, Stephen Woodbridge
> <woodbri at swoodbridge.com> wrote:
>> I just checked and it appears to be reproducible on both and I have
>> confirmed I can reproduce it on 5.2 b2 also.
>> For the png test I added map.imagetype=PNG8 and tried map.imagetype=png
>> where the mapfile has
>> OUTPUTFORMAT
>> NAME "agg/png24"
>> MIMETYPE "image/png"
>> DRIVER "AGG/PNG"
>> EXTENSION "png"
>> FORMATOPTION "PALETTE_FORCE=TRUE"
>> FORMATOPTION "PALETTE=/u/data/maps/palette-ayna-agg.txt"
>> END
>> OUTPUTFORMAT
>> NAME PNG8
>> DRIVER "GD/PNG"
>> EXTENSION "png"
>> IMAGEMODE RGBA
>> TRANSPARENT ON
>> FORMATOPTION "QUANTIZE_FORCE=ON"
>> FORMATOPTION "QUANTIZE_DITHER=OFF"
>> FORMATOPTION "QUANTIZE_COLORS=256"
>> END
>> [Fri Jun 20 23:06:41 2008] [error] [client 129.44.191.48] [Fri Jun 20
>> 23:06:41 2008].320026 msDrawMap(): Layer 0 (World), 0.059s
>> 23:06:41 2008].416089 msDrawMap(): Layer 1 (CountryZ1), 0.096s
>> 23:06:41 2008].419505 msDrawMap(): Layer 5 (Land Contour), 0.003s
>> 23:06:41 2008].460156 msDrawMap(): Layer 6 (World), 0.041s
>> 23:06:41 2008].544059
>> [Fri Jun 20 23:06:41 2008] [error] [client 129.44.191.48] msDrawMap(): Layer
>> 7 (CountryZ1), 0.084s
>> 23:06:41 2008].545289
>> 8 (Urban Areas), 0.001s
>> 23:06:41 2008].591990
>> 9 (Water p), 0.047s
>> 23:06:41 2008].593163
>> 10 (Water l), 0.001s
>> 23:06:41 2008].593603
>> 11 (Land Use), 0.000s
>> 23:06:41 2008].596240
>> 20 (City Placenames), 0.003s
>> 23:06:41 2008].629935 msDrawMap(): Layer 21 (City points), 0.034s
>> 23:06:41 2008].629979 msPOSTGISLayerOpen called datastatement: the_geom from
>> (select a.gid, a.fcc, a.the_geom, initcap(a.name) as name_out, a.name_alt as
>> name_arb from data.st a where a.fcc in ('A20')) as foo using SRID=4326
>> using unique gid
>> 23:06:41 2008].630000 MSPOSTGISLayerOpen -- shared connection not available.
>> 23:06:41 2008].635411 msConnPoolRegister(Streets A20,user=postgres
>> dbname=test3 host=localhost port=5432,0x1f9855f0)
>> 23:06:41 2008].635432 msPOSTGISLayerFreeItemInfo called
>> 23:06:41 2008].635444 msPOSTGISLayerInitItemInfo called
>> 23:06:41 2008].635454 msPOSTGISLayerWhichShapes called
>> 23:06:41 2008].635467 msPOSTGISLayerParseData: unique column = gid,
>> srid='4326', geom_column_name = the_geom, table_name=(select a.gid, a.fcc,
>> a.the_geom, initcap(a.name) as name_out, a.name_alt as name_arb from data.st
>> 23:06:41 2008].636178 query_string_0_6:DECLARE mycursor BINARY CURSOR FOR
>> SELECT
>> "name_out"::text,asbinary(force_collection(force_2d(the_geom)),'NDR'),gid::text
>> from (select a.gid, a.fcc, a.the_geom, initcap(a.name) as name_out,
>> a.name_alt as name_arb from data.st a where a.fcc in ('A20')) as foo WHERE
>> the_geom && setSRID('BOX3D(8.00592636360692
>> 36.6145187636069,9.22424883639308 37.8328412363931)'::BOX3D, 4326 )
>> 23:06:41 2008].681837 msPOSTGISLayerFreeItemInfo called
>> 23:06:41 2008].681875 msPOSTGISLayerClose datastatement: the_geom from
>> using unique gid
>> 23:06:41 2008].681885 msPOSTGISLayerClose -- closing query_result
>> 23:06:41 2008].682483 msConnPoolRelease(Streets A20,user=postgres
>> 23:06:41 2008].682496 msConnPoolClose(user=postgres dbname=test3
>> 23:06:41 2008].682535 msDrawMap(): Layer 22 (Streets A20), 0.053s
>> 23:06:41 2008].733862
>> 23 (Streets A10), 0.051s
>> 23:06:41 2008].734436
>> 25 (Placenames), 0.000s
>> 23:06:41 2008].768513 msDrawMap(): Layer 26 (City points), 0.034s
>> 23:06:41 2008].798392 msDrawMap(): Layer 27 (Airport p), 0.030s
>> 23:06:41 2008].828134 msDrawMap(): Layer 28 (Airport points), 0.030s
>> [Fri Jun 20 23:08:27 2008] [warn] [client 129.44.191.48] Timeout waiting for
>> output from CGI script /u/apache2/cgi-bin/mapserv
>> [Fri Jun 20 23:08:41 2008] [warn] [client 129.44.191.48] Timeout waiting for
>> output from CGI script /u/apache2/cgi-bin/mapserv-5.2b2
>> [Fri Jun 20 23:08:41 2008] [error] [client 129.44.191.48] Premature end of
>> script headers: mapserv-5.2b2
>> So this looks like it is probably in the labelcache processing where it is
>> timing out, it also seems to be malloc'ing memory based on strace before it
>> segv or times out and this is confirmed by top.
>> -Steve W
>> Steve Lime wrote:
>>> Is it present in both AGG and GD?
>>>>>> On 6/20/2008 at 5:42 PM, in message <485C3255.1090207 at swoodbridge.com>,
>>>>>> Stephen
>>> Woodbridge <woodbri at swoodbridge.com> wrote:
>>>> After spending 3 days chasing a problem that is making me nuts, I thought
>>>> I would post this much.
>>>> It is clearly label related because if we comment out the label block it
>>>> works fine.
>>>> I have been able to reproduce this in mapserver CGI just a short while
>>>> ago. I will try it with 5.2 when I have a chance and let you know what
>>>> happens.
>>>> Meanwhile, does this back trace look familiar? Thomas? Steve?
>>>> Thanks,
>>>> -Steve
>>>> MapServer version 5.0.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
>>>> OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
>>>> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=GEOS INPUT=EPPL7
>>>> INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
>>>> Program received signal SIGSEGV, Segmentation fault.
>>>> [Switching to Thread 46912496217952 (LWP 15375)]
>>>> 0x00002aaaae38ccb1 in agg::rasterizer_cells_aa<agg::cell_aa>::sort_cells
>>>> from /usr/lib64/extensions/no-debug-non-zts-20020429/php_mapscript.so
>>>> (gdb) bt
>>>> #0 0x00002aaaae38ccb1 in
>>>> agg::rasterizer_cells_aa<agg::cell_aa>::sort_cells ()
>>>> #1 0x00002aaaae39c396 in
>>>> agg::render_scanlines<agg::rasterizer_scanline_aa<agg::rasterizer_sl_clip<agg::
>>>> ras_conv_int> >,
>>>> agg::scanline_p8,
>>>> agg::renderer_scanline_aa_solid<agg::renderer_base<agg::pixfmt_alpha_blend_rgb
>>>> a<agg::blender_rgba_pre<agg::rgba8,
>>>> agg::order_bgra>, mapserv_row_ptr_cache<int>, int> > > > ()
>>>> #2 0x00002aaaae39cbb5 in
>>>> AGGMapserverRenderer::renderPathSolid<polygon_adaptor> ()
>>>> #3 0x00002aaaae386403 in msDrawShadeSymbolAGG () from
>>>> #4 0x00002aaaae36ae2b in msDrawLabelCache () from
>>>> #5 0x00002aaaae36f827 in msDrawMap () from
>>>> #6 0x00002aaaae328309 in php3_ms_map_draw () from
>>>> #7 0x00000000005255fb in execute (op_array=0xd88a418) at
>>>> /home/steve/work/php-4.4.8/Zend/zend_execute.c:1681
>>>> #8 0x000000000050d44b in zend_execute_scripts (type=8, retval=0x0,
>>>> file_count=3)
>>>> at /home/steve/work/php-4.4.8/Zend/zend.c:939
>>>> #9 0x00000000004e06fb in php_execute_script
>>>> (primary_file=0x7fff80acb250) at
>>>> /home/steve/work/php-4.4.8/main/main.c:1758
>>>> #10 0x0000000000529ed2 in main (argc=4, argv=0x7fff80acb398) at
>>>> /home/steve/work/php-4.4.8/sapi/cli/php_cli.c:838
>>>> _______________________________________________
>>>> mapserver-dev mailing list
>>>> mapserver-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
