[mapserver-dev] Almost forgot, beta3 today...
Tamas Szekeres szekerest at gmail.com
Thu Jun 26 08:22:15 EDT 2008
Assefa,
Yes it works fairly well, you can find the build/test results at the buildbot:
http://buildbot.osgeo.org:8504/waterfall
Could you confirm that the wxs test results are acceptable on the
various platforms by looking at the msautotest-wxs stdio links at the
buildbot?
We can find some mapserver errors here but unrelated to this problem.
Best regards,
Tamas
2008/6/26 Yewondwossen Assefa <yassefa at dmsolutions.ca>:
> Tamas,
>  I believe this is related to bug
> http://trac.osgeo.org/mapserver/ticket/2297
> I committed a fix few minutes ago, if you could please test and let me know.
> Thanks
> Tamas Szekeres wrote:
>> Steve,
>> Though I couldn't do a more detailed test it seems like the
>> wfs_filter_dwithin_units python test is failing. By invoking mapserv
>> with these parameters the process gets into a deadlocked state and
>> when breaking into the code I get the following call stack of the main
>> thread.
>> I hope some of us may have more knowledge about this portion of the
>> code to to find a fix more quickly than me.
>> Best regards,
>> Tamas
>>>        ntdll.dll!7d61c828()
>>        [Frames below may be incorrect and/or missing, no symbols loaded
>> for
>> ntdll.dll]
>>        ntdll.dll!7d628678()
>>        ntdll.dll!7d628576()
>>        ntdll.dll!7d625226()
>>        ntdll.dll!7d62757a()
>>        ntdll.dll!7d627607()
>>        ntdll.dll!7d6275b2()
>>        ntdll.dll!7d61cb0d()
>>        kernel32.dll!7d4dccfc()
>>        kernel32.dll!7d4dccd6()
>>        kernel32.dll!7d53577f()
>>        ntdll.dll!7d61f748()
>>        ntdll.dll!7d61f78c()
>>        kernel32.dll!7d4d9bba()
>>        kernel32.dll!7d4d0a58()
>>        ntdll.dll!7d61c858()
>>        kernel32.dll!7d4d08a8()
>>        kernel32.dll!7d4d08cb()
>>        ntdll.dll!7d61c92d()
>>        msvcr80.dll!78132c78()
>>        msvcr80.dll!78132e24()
>>        kernel32.dll!7d54eeb8()
>>        kernel32.dll!7d5116ba()
>>        kernel32.dll!7d4d8a25()
>>        ntdll.dll!7d61ec2a()
>>        ntdll.dll!7d61ebfb()
>>        ntdll.dll!7d63549e()
>>        ntdll.dll!7d61ea36()
>>        ntdll.dll!7d620ea5()
>>        msvcr80.dll!78134c58()
>>        libmap.dll!_msShapeFileLayerClose()  + 0x22 bytes       C
>>        libmap.dll!_msLayerClose()  + 0x68 bytes        C
>>        ntdll.dll!7d61f5ed()
>>        msvcr80.dll!78134c39()
>>        libmap.dll!_FLTApplyFilterToLayer()  + 0x3e bytes       C
>>        libmap.dll!_FLTFreeFilterEncodingNode()  + 0x48 bytes   C
>>        libmap.dll!_msWFSGetFeature()  + 0x921 bytes    C
>>        libmap.dll!_msWFSDispatch()  + 0x297 bytes      C
>>        libmap.dll!_msOWSDispatch()  + 0x63 bytes       C
>>        mapserv.exe!00404005()
>>        ntdll.dll!7d62f361()
>>        ntdll.dll!7d636f75()
>>        ntdll.dll!7d636fcf()
>>        ntdll.dll!7d6251d0()
>>        ntdll.dll!7d6251d7()
>>        ntdll.dll!7d62155b()
>>        kernel32.dll!7d534a7b()
>>        kernel32.dll!7d4dcd44()
>>        kernel32.dll!7d5124b8()
>>        ntdll.dll!7d61f645()
>>        msvcr80.dll!78132e2f()
>>        msvcr80.dll!78137021()
>>        msvcr80.dll!781370a0()
>>        msvcr80.dll!7813725c()
>>        msvcr80.dll!78132632()
>>        msvcr80.dll!7813271b()
>>        msvcr80.dll!78131d4f()
>>        mapserv.exe!00405b31()
>>        mapserv.exe!00405c55()
>>        kernel32.dll!7d4e7d2a()
>> 2008/6/26 Tamas Szekeres <szekerest at gmail.com>:
>>> Steve,
>>> I'm still not satisfied with the results mapserv.exe is hanging with
>>> the python tests on windows, I'm searching for the root of the problem
>>> and notify you if I find something.
>>> Best regards,
>>> Tamas
>>> 2008/6/25 Steve Lime <Steve.Lime at dnr.state.mn.us>:
>>>> Hi all: We are scheduled for another beta today. I have one bug that I
>>>> want to address tonight if possible related to the
>>>> entity_encoded_follow_text
>>>> test. It was introduced with label_pre_clip patch. What would folks
>>>> think about postponing the beta until tomorrow?
>>>> Steve
>>>> _______________________________________________
>>>> mapserver-dev mailing list
>>>> mapserver-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
> Assefa Yewondwossen
> Software Analyst
> Email: assefa at dmsolutions.ca
> http://www.dmsolutions.ca/
> Phone: (613) 565-5056 (ext 14)
> Fax:   (613) 565-0925
