[mapserver-dev] Support for the MapInfo style zoom layeringoption.
Steve Lime Steve.Lime at dnr.state.mn.us
Thu Jun 26 10:29:42 EDT 2008
We could establish precedence, if either of the scale values are set, then use those. If not, then check width.
That way you'd need just the two new members...
Steve
>>> On 6/25/2008 at 5:46 PM, in message
<f3b73b7d0806251546s3a82f8c8t9d1fbca169d2fb2a at mail.gmail.com>, "Tamas Szekeres"
<szekerest at gmail.com> wrote:
> Daniel,
> 2008/6/26 Daniel Morissette <dmorissette at mapgears.com>:
>> Tamas Szekeres wrote:
>>> Did you mean by adding 3 extra members to the layerObj or you are
>>> thinking about adding these new keywords only to the parser and the
>>> specified MINWIDTH/MAXWIDTH values would eventually be stored in the
>>> current minscaledemom/maxscaledenom members?
>> I meant also adding 2 new members in the layerObj as well... I think this is
>> more or less what you initially suggested, right?
> Yes that is exactly what I was proposing. How we distinguish between
> these 2 methods, should we think about an internal 'unspecified'
> value?
> like minwidth = -1 would mean that this parameter shouldn't actually
> be taken into account in msLayerIsVisible.
> Tamas
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
