[mapserver-dev] MapServer 5.2 Beta 3 Available
Jim Klassen
Jim.Klassen at ci.stpaul.mn.us
Fri Jun 27 11:54:32 EDT 2008
All,
Beta3 seems to have broken my tiled raster layers. These layers all worked fine up through 5.2.0-beta2. Is there something I need to change in my config?
The error I get is "msDrawMap(): Image handling error. Failed to draw layer named 'L10'. msDrawRaster(): Unable to access file. L10/512000_0-1024000_512000.jpg using full path L10/512000_0-1024000_512000.jpg"
In map I have SHAPEPATH set to "PWTS/2006_00"
In the layers I have TILEINDEX "L10/TILEINDEX"
In the tileindex I have Locations such as "L10/512000_0-1024000_512000.jpg"
The file system layout is:
./AERIAL_2006/ramsey_2006.map
./AERIAL_2006/PWTS/2006_00/L10/TILEINDEX.{shp,shx,dbf}
./AERIAL_2006/PWTS/2006_00/L10/*.jpg
Jim Klassen
City of St. Paul
>>> "Steve Lime" <Steve.Lime at dnr.state.mn.us> 06/26/08 10:00 PM >>>
- mapshape.c: Applied patch to make the location of tiled data relative to the
tileindex directory if SHAPEPATH is not set. (#2369)
