[mapserver-dev] MapServer 5.2 Beta 3 Available
David Fuhry
dfuhry at acm.org
Fri Jun 27 16:53:29 EDT 2008
Paul,
For an absolute shapepath, the shapepath clobbers tiFileAbsDir (the
absolute path of the tileindex file's directory), and I think things
work correctly.
But the relative shapepath case is not handled correctly. I'm
thinking that the correct logic needs a branch, and should look like this:
if(layer->tileindex) {
if (map->shapepath)
msBuildPath(szPath, map->shapepath, filename);
} else {
msBuildPath(tiAbsFilePath, map->mappath, layer->tileindex); /*
absolute path to tileindex file */
tiAbsDirPath = msGetPath(tiAbsFilePath); /* tileindex file's
directory */
msBuildPath(szPath, tiAbsDirPath, filename);
free(tiAbsDirPath);
} else {
msBuildPath3(szPath, map->mappath, map->shapepath, filename);
Is the lower else clause still ok?
Thanks,
Dave
Paul Ramsey wrote:
> This doesn't seem right to me:
> msBuildPath3(szPath, tiFileAbsDir, layer->map->shapepath, filename);
> If shapepath isn't set, you get the right answer, but if it *is* set,
> you get something very odd indeed.
> P.
> On Fri, Jun 27, 2008 at 12:50 PM, Jeff McKenna
> <jmckenna at gatewaygeomatics.com> wrote:
>> Jim,
>> There was indeed a change in beta3 regarding TILEINDEX layers, but it should
>> not affect any existing indexes with SHAPEPATH set, which is your case. I
>> can duplicate your error with a file structure exactly like yours: with
>> beta2 no error, with beta3 i get your exact errors. Would you mind
>> reporting this in the associated ticket?
>> http://trac.osgeo.org/mapserver/ticket/2369 Also please include what OS you
>> are testing on (I am testing on Windows).
>> Good find!
>> Jeff McKenna
>> FOSS4G Consulting and Training Services
>> http://www.gatewaygeomatics.com/
>> On 27-Jun-08, at 11:54 AM, Jim Klassen wrote:
>>> All,
>>> Beta3 seems to have broken my tiled raster layers. These layers all worked
>>> fine up through 5.2.0-beta2. Is there something I need to change in my
>>> config?
>>> The error I get is "msDrawMap(): Image handling error. Failed to draw
>>> layer named 'L10'. msDrawRaster(): Unable to access file.
>>> L10/512000_0-1024000_512000.jpg using full path
>>> L10/512000_0-1024000_512000.jpg"
>>> In map I have SHAPEPATH set to "PWTS/2006_00"
>>> In the layers I have TILEINDEX "L10/TILEINDEX"
>>> In the tileindex I have Locations such as
>>> "L10/512000_0-1024000_512000.jpg"
>>> The file system layout is:
>>> ./AERIAL_2006/ramsey_2006.map
>>> ./AERIAL_2006/PWTS/2006_00/L10/TILEINDEX.{shp,shx,dbf}
>>> ./AERIAL_2006/PWTS/2006_00/L10/*.jpg
>>> Jim Klassen
>>> City of St. Paul
>>>>>> "Steve Lime" <Steve.Lime at dnr.state.mn.us> 06/26/08 10:00 PM >>>
>>> - mapshape.c: Applied patch to make the location of tiled data relative to
>>> the
>>> tileindex directory if SHAPEPATH is not set. (#2369)
>>> mapserver-dev mailing list
>>> mapserver-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
