[mapserver-dev] MapServer 5.2 Beta 3 Available
David Fuhry
dfuhry at acm.org
Fri Jun 27 17:33:31 EDT 2008
Paul,
I'm under the impression the discussion is about raster tileindexes,
not shapefile tileindexes. I'm more ignorant about the latter, and its
patch was riskier and more invasive, so I have no problem with whatever
compromises have to be made with the shapefile tileindexes patch
(including not merging for 5.2).
With raster tileindexes however, I think the changes are realistic;
I attached a two-line patch to
http://trac.osgeo.org/mapserver/ticket/2369 (also attached here).
Jim, does the attached patch fix the Image handling error for you?
Thanks,
Dave
Paul Ramsey wrote:
> David, I agree, it's the relative shapepath case that is failing.
> You may not like this but I replicated the old logic and just added
> yours to the top. I think that your idea that in general things are
> either absolute paths or work is correct, so this ugly code should not
> be too slow. And I like that it actually falls back: if the file is
> missing in one place, it'll check another.
> Patch attached.
> On Fri, Jun 27, 2008 at 1:53 PM, David Fuhry <dfuhry at acm.org> wrote:
>> Paul,
>> For an absolute shapepath, the shapepath clobbers tiFileAbsDir (the
>> absolute path of the tileindex file's directory), and I think things work
>> correctly.
>> But the relative shapepath case is not handled correctly. I'm thinking
>> that the correct logic needs a branch, and should look like this:
>> if(layer->tileindex) {
>> if (map->shapepath)
>> msBuildPath(szPath, map->shapepath, filename);
>> } else {
>> msBuildPath(tiAbsFilePath, map->mappath, layer->tileindex); /*
>> absolute path to tileindex file */
>> tiAbsDirPath = msGetPath(tiAbsFilePath); /* tileindex file's
>> directory */
>> msBuildPath(szPath, tiAbsDirPath, filename);
>> free(tiAbsDirPath);
>> } else {
>> msBuildPath3(szPath, map->mappath, map->shapepath, filename);
>> Is the lower else clause still ok?
>> Thanks,
>> Dave
>> Paul Ramsey wrote:
>>> This doesn't seem right to me:
>>> msBuildPath3(szPath, tiFileAbsDir, layer->map->shapepath, filename);
>>> If shapepath isn't set, you get the right answer, but if it *is* set,
>>> you get something very odd indeed.
>>> P.
>>> On Fri, Jun 27, 2008 at 12:50 PM, Jeff McKenna
>>> <jmckenna at gatewaygeomatics.com> wrote:
>>>> Jim,
>>>> There was indeed a change in beta3 regarding TILEINDEX layers, but it
>>>> should
>>>> not affect any existing indexes with SHAPEPATH set, which is your case.
>>>> I
>>>> can duplicate your error with a file structure exactly like yours: with
>>>> beta2 no error, with beta3 i get your exact errors. Would you mind
>>>> reporting this in the associated ticket?
>>>> http://trac.osgeo.org/mapserver/ticket/2369 Also please include what OS
>>>> you
>>>> are testing on (I am testing on Windows).
>>>> Good find!
>>>> Jeff McKenna
>>>> FOSS4G Consulting and Training Services
>>>> http://www.gatewaygeomatics.com/
>>>> On 27-Jun-08, at 11:54 AM, Jim Klassen wrote:
>>>>> All,
>>>>> Beta3 seems to have broken my tiled raster layers. These layers all
>>>>> worked
>>>>> fine up through 5.2.0-beta2. Is there something I need to change in my
>>>>> config?
>>>>> The error I get is "msDrawMap(): Image handling error. Failed to draw
>>>>> layer named 'L10'. msDrawRaster(): Unable to access file.
>>>>> L10/512000_0-1024000_512000.jpg using full path
>>>>> L10/512000_0-1024000_512000.jpg"
>>>>> In map I have SHAPEPATH set to "PWTS/2006_00"
>>>>> In the layers I have TILEINDEX "L10/TILEINDEX"
>>>>> In the tileindex I have Locations such as
>>>>> "L10/512000_0-1024000_512000.jpg"
>>>>> The file system layout is:
>>>>> ./AERIAL_2006/ramsey_2006.map
>>>>> ./AERIAL_2006/PWTS/2006_00/L10/TILEINDEX.{shp,shx,dbf}
>>>>> ./AERIAL_2006/PWTS/2006_00/L10/*.jpg
>>>>> Jim Klassen
>>>>> City of St. Paul
>>>>>>>> "Steve Lime" <Steve.Lime at dnr.state.mn.us> 06/26/08 10:00 PM >>>
>>>>> - mapshape.c: Applied patch to make the location of tiled data relative
>>>>> to
>>>>> the
>>>>> tileindex directory if SHAPEPATH is not set. (#2369)
>>>>> _______________________________________________
>>>>> mapserver-dev mailing list
>>>>> mapserver-dev at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20080627/351bd409/ms_mapraster_correct_rel_shapepath.v1.bin
