[mapserver-dev] MapServer 5.2 Beta 3 Available
Jeff McKenna
jmckenna at gatewaygeomatics.com
Fri Jun 27 19:24:07 EDT 2008
- tested Dave's patch with a raster tileindex: passed
- created vector tileindex with file structure similar to Jim's
original one
- Paul's patch complains at first, as it checks for relative to
tileindex path, and passes (creates map image) as it checks for
relative to shapepath
-jeff
On 27-Jun-08, at 5:46 PM, Paul Ramsey wrote:
> OK, between the two patches, then, we're in good shape (assuming my
> patch worked, jeff?). Yes, I addressed your larger shapetile patch and
> totally missed the mapraster.c issue, rah! Your patch will fix. Still
> leaves a behavior change, but I'm prepared to believe it's not
> something anyone will run across.
> P.
> On Fri, Jun 27, 2008 at 2:33 PM, David Fuhry <dfuhry at acm.org> wrote:
>> Paul,
>> I'm under the impression the discussion is about raster
>> tileindexes, not
>> shapefile tileindexes. I'm more ignorant about the latter, and its
>> patch
>> was riskier and more invasive, so I have no problem with whatever
>> compromises have to be made with the shapefile tileindexes patch
>> (including
>> not merging for 5.2).
>> With raster tileindexes however, I think the changes are
>> realistic; I
>> attached a two-line patch to http://trac.osgeo.org/mapserver/ticket/2369
>> (also attached here).
>> Jim, does the attached patch fix the Image handling error for you?
>> Thanks,
>> Dave
>> Paul Ramsey wrote:
>>> David, I agree, it's the relative shapepath case that is failing.
>>> You may not like this but I replicated the old logic and just added
>>> yours to the top. I think that your idea that in general things are
>>> either absolute paths or work is correct, so this ugly code should
>>> not
>>> be too slow. And I like that it actually falls back: if the file is
>>> missing in one place, it'll check another.
>>> Patch attached.
>>> On Fri, Jun 27, 2008 at 1:53 PM, David Fuhry <dfuhry at acm.org> wrote:
>>>> Paul,
>>>> For an absolute shapepath, the shapepath clobbers tiFileAbsDir (the
>>>> absolute path of the tileindex file's directory), and I think
>>>> things work
>>>> correctly.
>>>> But the relative shapepath case is not handled correctly. I'm
>>>> thinking
>>>> that the correct logic needs a branch, and should look like this:
>>>> if(layer->tileindex) {
>>>> if (map->shapepath)
>>>> msBuildPath(szPath, map->shapepath, filename);
>>>> } else {
>>>> msBuildPath(tiAbsFilePath, map->mappath, layer->tileindex); /*
>>>> absolute path to tileindex file */
>>>> tiAbsDirPath = msGetPath(tiAbsFilePath); /* tileindex file's
>>>> directory */
>>>> msBuildPath(szPath, tiAbsDirPath, filename);
>>>> free(tiAbsDirPath);
>>>> } else {
>>>> msBuildPath3(szPath, map->mappath, map->shapepath, filename);
>>>> Is the lower else clause still ok?
>>>> Thanks,
>>>> Dave
>>>> Paul Ramsey wrote:
>>>>> This doesn't seem right to me:
>>>>> msBuildPath3(szPath, tiFileAbsDir, layer->map->shapepath,
>>>>> filename);
>>>>> If shapepath isn't set, you get the right answer, but if it *is*
>>>>> set,
>>>>> you get something very odd indeed.
>>>>> P.
>>>>> On Fri, Jun 27, 2008 at 12:50 PM, Jeff McKenna
>>>>> <jmckenna at gatewaygeomatics.com> wrote:
>>>>>> Jim,
>>>>>> There was indeed a change in beta3 regarding TILEINDEX layers,
>>>>>> but it
>>>>>> should
>>>>>> not affect any existing indexes with SHAPEPATH set, which is
>>>>>> your case.
>>>>>> I
>>>>>> can duplicate your error with a file structure exactly like
>>>>>> yours: with
>>>>>> beta2 no error, with beta3 i get your exact errors. Would you
>>>>>> mind
>>>>>> reporting this in the associated ticket?
>>>>>> http://trac.osgeo.org/mapserver/ticket/2369 Also please
>>>>>> include what
>>>>>> OS
>>>>>> you
>>>>>> are testing on (I am testing on Windows).
>>>>>> Good find!
>>>>>> Jeff McKenna
>>>>>> FOSS4G Consulting and Training Services
>>>>>> http://www.gatewaygeomatics.com/
>>>>>> On 27-Jun-08, at 11:54 AM, Jim Klassen wrote:
>>>>>>> All,
>>>>>>> Beta3 seems to have broken my tiled raster layers. These
>>>>>>> layers all
>>>>>>> worked
>>>>>>> fine up through 5.2.0-beta2. Is there something I need to
>>>>>>> change in my
>>>>>>> config?
>>>>>>> The error I get is "msDrawMap(): Image handling error. Failed
>>>>>>> to draw
>>>>>>> layer named 'L10'. msDrawRaster(): Unable to access file.
>>>>>>> L10/512000_0-1024000_512000.jpg using full path
>>>>>>> L10/512000_0-1024000_512000.jpg"
>>>>>>> In map I have SHAPEPATH set to "PWTS/2006_00"
>>>>>>> In the layers I have TILEINDEX "L10/TILEINDEX"
>>>>>>> In the tileindex I have Locations such as
>>>>>>> "L10/512000_0-1024000_512000.jpg"
>>>>>>> The file system layout is:
>>>>>>> ./AERIAL_2006/ramsey_2006.map
>>>>>>> ./AERIAL_2006/PWTS/2006_00/L10/TILEINDEX.{shp,shx,dbf}
>>>>>>> ./AERIAL_2006/PWTS/2006_00/L10/*.jpg
>>>>>>> Jim Klassen
>>>>>>> City of St. Paul
>>>>>>>>>> "Steve Lime" <Steve.Lime at dnr.state.mn.us> 06/26/08 10:00 PM
>>>>>>> - mapshape.c: Applied patch to make the location of tiled data
>>>>>>> relative
>>>>>>> to
>>>>>>> the
>>>>>>> tileindex directory if SHAPEPATH is not set. (#2369)
>>>>>>> _______________________________________________
>>>>>>> mapserver-dev mailing list
>>>>>>> mapserver-dev at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
