[mapserver-dev] MapServer 5.2 Beta 3 Available
Stephen Woodbridge woodbri at swoodbridge.com
Sat Jun 28 15:49:07 EDT 2008
If we do another beta would be be reasonable to include the patch added
to #2664. If so, can someone that knows about configure review the patch
for aboudreault.
Thanks,
   Steve W
Steve Lime wrote:
> Thanks for working on that guys! (was out of the office yesterday) Is
> this a case for a beta4 next week then?
> Steve
>>>> Jeff McKenna <jmckenna at gatewaygeomatics.com> 06/27/08 6:24 PM
> - tested Dave's patch with a raster tileindex: passed - created
> vector tileindex with file structure similar to Jim's original one -
> Paul's patch complains at first, as it checks for relative to
> tileindex path, and passes (creates map image) as it checks for
> relative to shapepath
> -jeff
> On 27-Jun-08, at 5:46 PM, Paul Ramsey wrote:
>> OK, between the two patches, then, we're in good shape (assuming my
>>  patch worked, jeff?). Yes, I addressed your larger shapetile patch
>> and totally missed the mapraster.c issue, rah! Your patch will fix.
>> Still leaves a behavior change, but I'm prepared to believe it's
>> not something anyone will run across.
>> P.
>> On Fri, Jun 27, 2008 at 2:33 PM, David Fuhry <dfuhry at acm.org>
>> wrote:
>>> Paul,
>>> I'm under the impression the discussion is about raster
>>> tileindexes, not shapefile tileindexes.  I'm more ignorant about
>>> the latter, and its patch was riskier and more invasive, so I
>>> have no problem with whatever compromises have to be made with
>>> the shapefile tileindexes patch (including not merging for 5.2).
>>> With raster tileindexes however, I think the changes are
>>> realistic; I attached a two-line patch to
>>> http://trac.osgeo.org/mapserver/ticket/2369 (also attached here).
>>> Jim, does the attached patch fix the Image handling error for
>>> you?
>>> Thanks,
>>> Dave
>>> Paul Ramsey wrote:
>>>> David, I agree, it's the relative shapepath case that is
>>>> failing.
>>>> You may not like this but I replicated the old logic and just
>>>> added yours to the top. I think that your idea that in general
>>>> things are either absolute paths or work is correct, so this
>>>> ugly code should not be too slow. And I like that it actually
>>>> falls back: if the file is missing in one place, it'll check
>>>> another.
>>>> Patch attached.
>>>> On Fri, Jun 27, 2008 at 1:53 PM, David Fuhry <dfuhry at acm.org>
>>>> wrote:
>>>>> Paul,
>>>>> For an absolute shapepath, the shapepath clobbers
>>>>> tiFileAbsDir (the absolute path of the tileindex file's
>>>>> directory), and I think things work correctly.
>>>>> But the relative shapepath case is not handled correctly.
>>>>> I'm thinking that the correct logic needs a branch, and
>>>>> should look like this:
>>>>> if(layer->tileindex) { if (map->shapepath) {
>>>>> msBuildPath(szPath, map->shapepath, filename); } else {
>>>>> msBuildPath(tiAbsFilePath, map->mappath, layer->tileindex);
>>>>> /* absolute path to tileindex file */ tiAbsDirPath =
>>>>> msGetPath(tiAbsFilePath); /* tileindex file's directory */
>>>>> msBuildPath(szPath, tiAbsDirPath, filename);
>>>>> free(tiAbsDirPath); } } else { msBuildPath3(szPath,
>>>>> map->mappath, map->shapepath, filename); }
>>>>> Is the lower else clause still ok?
>>>>> Thanks,
>>>>> Dave
>>>>> Paul Ramsey wrote:
>>>>>> This doesn't seem right to me:
>>>>>> msBuildPath3(szPath, tiFileAbsDir, layer->map->shapepath,
>>>>>>  filename);
>>>>>> If shapepath isn't set, you get the right answer, but if it
>>>>>> *is* set, you get something very odd indeed.
>>>>>> P.
>>>>>> On Fri, Jun 27, 2008 at 12:50 PM, Jeff McKenna
>>>>>> <jmckenna at gatewaygeomatics.com> wrote:
>>>>>>> Jim,
>>>>>>> There was indeed a change in beta3 regarding TILEINDEX
>>>>>>> layers, but it should not affect any existing indexes
>>>>>>> with SHAPEPATH set, which is your case. I can duplicate
>>>>>>> your error with a file structure exactly like yours: with
>>>>>>>  beta2 no error, with beta3 i get your exact errors.
>>>>>>> Would you mind reporting this in the associated ticket?
>>>>>>> http://trac.osgeo.org/mapserver/ticket/2369  Also please
>>>>>>>  include what OS you are testing on (I am testing on
>>>>>>> Windows).
>>>>>>> Good find!
>>>>>>> --- Jeff McKenna FOSS4G Consulting and Training Services
>>>>>>> http://www.gatewaygeomatics.com/
>>>>>>> On 27-Jun-08, at 11:54 AM, Jim Klassen wrote:
>>>>>>>> All,
>>>>>>>> Beta3 seems to have broken my tiled raster layers.
>>>>>>>> These layers all worked fine up through 5.2.0-beta2. Is
>>>>>>>> there something I need to change in my config?
>>>>>>>> The error I get is "msDrawMap(): Image handling error.
>>>>>>>> Failed to draw layer named 'L10'. msDrawRaster():
>>>>>>>> Unable to access file. L10/512000_0-1024000_512000.jpg
>>>>>>>> using full path L10/512000_0-1024000_512000.jpg"
>>>>>>>> In map I have SHAPEPATH set to "PWTS/2006_00" In the
>>>>>>>> layers I have TILEINDEX "L10/TILEINDEX" In the
>>>>>>>> tileindex I have Locations such as
>>>>>>>> "L10/512000_0-1024000_512000.jpg"
>>>>>>>> The file system layout is:
>>>>>>>> ./AERIAL_2006/ramsey_2006.map
>>>>>>>> ./AERIAL_2006/PWTS/2006_00/L10/TILEINDEX.{shp,shx,dbf}
>>>>>>>> ./AERIAL_2006/PWTS/2006_00/L10/*.jpg
>>>>>>>> Jim Klassen City of St. Paul
>>>>>>>>>>> "Steve Lime" <Steve.Lime at dnr.state.mn.us>
>>>>>>>>>>> 06/26/08 10:00 PM
>>>>>>>> - mapshape.c: Applied patch to make the location of
>>>>>>>> tiled data relative to the tileindex directory if
>>>>>>>> SHAPEPATH is not set. (#2369)
>>>>>>>> _______________________________________________
>>>>>>>> mapserver-dev mailing list
>>>>>>>> mapserver-dev at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
>>>>>>> mapserver-dev mailing list mapserver-dev at lists.osgeo.org
> _______________________________________________ mapserver-dev mailing
