[mapserver-dev] Problem with label angle since v5.0
Steve Lime
Steve.Lime at dnr.state.mn.us
Mon Jun 30 10:13:13 EDT 2008
It's too late for 5.2. I have created a bug for this (http://trac.osgeo.org/mapserver/ticket/2670) and will add this
to the main trunk as soon as we branch 5.2.
Steve
>>> On 6/26/2008 at 2:06 AM, in message <18127742.post at talk.nabble.com>, tommyr
<nerkeilenemon at gmail.com> wrote:
> Yes it would work for me.
> I agree that the getBinding() method is missing.
> I hope it will be present in the next version of MapServer ;)
> Good Bye, Thank You.
> Tommy
> Steve Lime wrote:
>> As it sits if you set a binding programmatically, like so:
>> $label->setBinding(MS_LABEL_BINDING_ANGLE, 'myitem');
>> or in a map file there is no way to get at the column name. We'd need a
>> getBinding method in MapScript so you could do something like:
>> $item = $label->getBinding(MS_LABEL_BINDING_ANGLE);
>> and $item would contain the string 'myitem'. This would work for you,
>> correct?
>> Steve
>>>>> tommyr <nerkeilenemon at gmail.com> 06/13/08 1:47 AM >>>
>> Hello,
>> I still have my problem, i can't solve it.
>> Did you find a solution ?
>> Thank you,
>> Tommy
>> Steve Lime wrote:
>>> Ah, I get it. Let me ponder that and get back to you.
>>> Steve
>>>>>> On 5/23/2008 at 2:22 AM, in message <17419520.post at talk.nabble.com>,
>>>>>> tommyr
>>>> In fact I want to get back the value of the angle of the label i mean
>>>> this :
>>>> angle [THIS].
>>>> I set a value into it with
>>>> $oLabelObj->setBinding(MS_LABEL_BINDING_ANGLE,
>>>> 'THIS'), and then I wan't to get the value of the angle I put to the
>>>> label.
>>>> How can I do this ?
>>>> Thank you.
>>>> Tommy
>>>> Steve Lime wrote:
>>>>> Hi Tommy: I guess I'm not clear on what you're after. Bindings are
>>>>> evaluated on a feature by feature basis
>>>>> during rendering so the value for the label will change repeatedly. In
>>>>> what context would you want to see
>>>>> the angle?
>>>>> Steve
>>>>>>>> On 5/22/2008 at 10:42 AM, in message
>>>>> <7b2d12b90805220842wb1c7c9dm6d9065040f1d8709 at mail.gmail.com>, "Tommy
>>>>> Roughol"
>>>>>> Hello,
>>>>>> I have a problem since the release of Map Server 5. I now set the
>>>>>> angle
>>>>>> of
>>>>>> my LabelObj with $oLabelObj->setBinding(MS_LABEL_BINDING_ANGLE, ...) .
>>>>>> Nevertheless, I can't get the value of my LabelObj, because
>>>>>> $oLabelObj->angle is a double, with value = 0, and there is no method
>>>>>> getBinding(). Is there a way to get the value of the angle string in
>>>>>> my
>>>>>> label ? A method, a void, or anything else ?
>>>>>> Thank You.
>>>>> _______________________________________________
>>>>> mapserver-dev mailing list
>>>>> mapserver-dev at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
>> View this message in context:
>> http://www.nabble.com/Problem-with-label-angle-since-v5.0-tp17407112p17816191.html
>> Sent from the Mapserver - Dev mailing list archive at Nabble.com.
