[MAPSERVER-DEV] How to generate 3d image like GPS device?
thomas bonfort thomas.bonfort at gmail.com
Sat Mar 8 13:30:31 EST 2008
oops... just (re?)read the thread and see that I implemented exactly
what you where proposing, sorry for the paternity of that ;) although
I think that if we do go along this line, it might be more flexible to
use a real projection matrix rather than limiting ourselves to this
kind of scaling.
rotation wrt to north facing upwards will probably be a bit more
problematic, as the letters of labels are oriented to be readable when
the map is oriented to the north and could possibly be upside down if
requesting a rotated view, but I think it may be overcome with a
specialized msTransformShapeXXX function that could account for the
rotational part of the requested view. we'd still have to investigate
how to treat the extent of the requested view wrt clipping of shapes
though.
I'll add myself to the soc wiki page on this subject
regards,
thomas
>  On Wed, Feb 27, 2008 at 5:27 PM, Brent Fraser <bfraser at geoanalytic.com> wrote:
>  > Stephen,
>  >   A cheap way to approximate the projective transformation
>  >  might be to apply a x-axis scaling with the scaling factor
>  >  varying linearly along the y-axis, basically squishing it at
>  >  the top.  In other words, render the map image, then
>  >  resample each line of pixels (with a resampling value of say
>  >  10% for the top line of pixels to 100% of the bottom line),
>  >  then clip and add other stuff (sky etc).  Then there's the
>  >  problem of heading-up instead of north-up.  The map file
>  >  does have a rotation setting, which might help.
>  >   In the end, I think a more rigorous projective
>  >  transformation would give better results (preserving line
>  >  widths, etc).  And there may be so many "special" features
>  >  that it would make more sense to have a separate "NavServer"
>  >  (with its own map file/API objects) instead of
>  >  warping/adding-noise to the more traditional MapServer to do
>  >  the task.  But as Steve Lime say, it would be cool to see in
>  >  Mapserver.  And 3d is the future...
>  >  Brent Fraser
>  >  GeoAnalytic Inc.
>  >  Calgary, Alberta
>  >  ----- Original Message -----
>  >  From: "Stephen Woodbridge" <woodbri at SWOODBRIDGE.COM>
>  >  To: <MAPSERVER-DEV at LISTS.UMN.EDU>
>  > Sent: Wednesday, February 27, 2008 7:57 AM
>  >  Subject: Re: [MAPSERVER-DEV] How to generate 3d image like
>  >  GPS device?
>  > > Tamas Szekeres wrote:
>  >  > > 2008/2/27, Stephen Woodbridge <woodbri at swoodbridge.com>:
>  >  > >> Hi all,
>  >  > >>  Sorry for the cross posting. I need to find out how to
>  >  make mapserver
>  >  > >>  generate map images that appear like the 3D mode of
>  >  GPS devices. See
>  >  > >>  attached image.
>  >  > >>  Has anyone done this? How?
>  >  > >>  Any thoughts on how to to hack the code to do this?
>  >  > > Stephen,
>  >  > > I think we should add a special renderer for doing such
>  >  things, and it
>  >  > > would require to do some additional coordinate
>  >  transformations for the
>  >  > > shapes and additional special effects like  drawing the
>  >  horizon and
>  >  > > use gradient fade out for distant areas etc. I don't
>  >  think it would be
>  >  > > a scope of instant hack in the code.
>  >  > Tamas,
>  >  > Thank you for your response.
>  >  > Yes, you may be right. I think there are a variety of
>  >  levels of
>  >  > implementation. Initially just getting mapserver to render
>  >  a tilted view
>  >  > without all the special effects would be a start. I was
>  >  thinking of the
>  >  > possibility of hacking the projection matrix to achieve
>  >  this, although
>  >  > I'm not sure how or if that is possible.
>  >  > The image also has an implied point of viewer that is used
>  >  to orient
>  >  > "up" for the image.
>  >  > > I wonder which use case would make this option
>  >  reasonable though. Are
>  >  > > you planning to utilize a permanent client-server
>  >  connection with the
>  >  > > mobile application, or compile mapserver to your mobile
>  >  platform?
>  >  > Mobile devices can be Windows/Linux laptops along with
>  >  those normally
>  >  > thought of as mobile.
>  >  > Best regards,
>  >  >    -Steve W
>  >  > > Best regards,
>  >  > > Tamas
