[mapserver-dev] [discuss] featurereader, tileservice,
map.open() problem
Áron Deák
deakaron at gmail.com
Tue Mar 11 12:20:14 EDT 2008
Hello everybody,
I am new to mapguide. I am writing a java thick client map application using
MapGuide Open Source as map server. I query images from the map server, this
part works pretty well, not fast enought tough.
My problem is that I also need to be able to read the feature data in order
to be able to provide some simplified geocoding service as well, but I can't
get the feature reader to work, I also need the tile service because
rendering images takes a lot of time and even implementing tile caching in
the program is not enough, so I would like to use MapGuide's tile service as
well reading tile data through MgByteReader in a similar way as reading
arbitrary sized images.
I have problem running even the simplest sample codes, eg. map.Open()
function throws an exception so I have to use map.Create() to open a map and
I am thinking that this might be the root of my problems.
Here is how my code works: (simplified) I have followed instruction from the
GettingStartedGuide.pdf to the letter when installing the MapGuide server
try {
MapGuideJavaApi.MgInitializeWebTier("C:\\webconfig.ini");
MgUserInformation userInfo = new MgUserInformation("Anonymous",
mapDefid = new MgResourceIdentifier(
"Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition");
MgSite site = new MgSite();
site.Open(userInfo);
String sessionId = site.CreateSession();
site.Close();
MgSiteConnection siteConnection = new MgSiteConnection();
siteConnection.Open(userInfo);
MgResourceService service = (MgResourceService) siteConnection
.CreateService(MgServiceType.ResourceService);
MgMap map;
map = new MgMap();
MgRenderingService renderingService = (MgRenderingService)
siteConnection
.CreateService(MgServiceType.RenderingService);
MgFeatureService featureService = (MgFeatureService)
siteConnection
.CreateService(MgServiceType.FeatureService);
MgTileService tileService = (MgTileService) siteConnection
.CreateService(MgServiceType.TileService);
MgResourceService resourceService = (MgResourceService)
siteConnection
map.Create(resourceService, mapDefid, "MyMap");
* Opening map throws exception
// map.Open(resourceService, "Sheboygan");
MgResourceIdentifier districtsId = new MgResourceIdentifier(
"Library://Samples/Sheboygan/Data/VotingDistricts.FeatureSource");
* Selecting features throws exception
// featureService.SelectFeatures(districtsId, "VotingDistricts",
// new MgFeatureQueryOptions(), "Sheboygan");
* Reading a certain area of the map as an image file stream
works fine
MgByteReader reader = this.mapGuideResourceManager
.getRenderingService().RenderMap(map,
this.mapGuideResourceManager.getSelection(), env,
(int) renderSpec.getImageSize().getWidth(),
(int) renderSpec.getImageSize().getHeight(),
new MgColor((short) 0, (short) 0, (short) 0xff),
"JPG");
} catch (MgException ex) {
ex.printStackTrace();
Any help or ideas would be appreciated, now I am stuck with the development
because of these problems.
Thanks,
aron deak
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20080311/419c62e3/attachment.html
