[mapserver-dev] Proposed maporaclespatial.c header...
Fernando Simon
fsimon at univali.br
Fri Mar 14 16:54:15 EDT 2008
Hi all,
I agree that the "Oracle Spatial" term is better. When you
install/enable the Spatial in Oracle Database server you select
Oracle Spatial option (or just Spatial in some versions).
IMHO the Oracle Spatial term need to continue, the source code name
can change without problem, but the "SUPPORTS", and "--with" need to
point Oracle Spatial. And the Oracle uses the "Oracle Spatial" term.
Best regards.
Fernando Simon
Citando "Bart van den Eijnden (OSGIS)" <bartvde at osgis.nl>:
> I agree with Frank, also more people will understand the term
> Oracle
> Spatial than SDO.
> Best regards,
> Bart
> Frank Warmerdam wrote:
> > Steve Lime wrote:
> >> I'm +1 as well. I'd also want to change OracleSpatial to SDO in
> the
> >> version output and build
> >> parameters (e.g. USE_SDO) as well.
> > Folks,
> > What is driving this renaming? It seems like unnecessary churn
> that will
> > cause minor problems in the future. Harder to migrate patches.
> > Tutorials
> > that talk about SUPPORTS=ORACLESPATIAL will be wrong, etc.
> > The header change looks fine to me.
> > Best regards,
> OSGIS, Open Source GIS
> bartvde at osgis.nl
> http://www.osgis.nl
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Univali - Webmail - http://webmail.univali.br
