[mapserver-dev] RFC 24 Changes to
	mapscript/perl/plmodule.i
    Steve Lime
    Steve.Lime at dnr.state.mn.us
    Thu Mar 20 10:59:35 EDT 2008
Not sure on the build problems (not my fault for a change), so I won't update my
source files for a while. I'll try your patch though, seems like an easy fix. Is the
module name (as defined in mapscript.i) available as an env variable? Or perhaps
we could set it there for all subsequent .i files to use?
Steve
>>> On 3/20/2008 at 3:42 AM, in message
<75b4b93e0803200142m57e1892l6c3d1f2aaa7a93a0 at mail.gmail.com>, "Umberto
Nicoletti" <umberto.nicoletti at gmail.com> wrote:
> I was trying to help you out on this one (see attached patch), but I
> can't compile mapserver:
> unicoletti at ziggy ~/Workspace/eclipse/subversion/sandox/mapserver $make
> gcc -c -O2 -fPIC -Wall     -DHAVE_VSNPRINTF -DNEED_STRLCAT
>  -DUSE_WMS_SVR      -DUSE_GDAL  -DUSE_GEOS  -DUSE_THREAD -DUSE_PROJ
> -DUSE_EPPL     -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP
> -DUSE_GD_FT -DGD_HAS_FTEX_XSHOW -DGD_HAS_GDIMAGEGIFPTR
> -DGD_HAS_GETBITMAPFONTS -DUSE_ICONV -DUSE_ZLIB     -I/usr/include
>   -I/usr/include/gdal      -I/usr/include      mapwfs11.c -o
> mapwfs11.o
> In file included from mapwfs11.c:32:
> mapows.h:31: error: expected specifier-qualifier-list before 'rectObj'
> mapows.h:97: error: expected specifier-qualifier-list before 'hashTableObj'
> mapows.h:116: error: expected '=', ',', ';', 'asm' or '__attribute__'
> before 'int'
> mapows.h:120: error: expected '=', ',', ';', 'asm' or '__attribute__'
> before 'int'
> mapows.h:121: error: expected '=', ',', ';', 'asm' or '__attribute__'
> before 'int'
> mapows.h:122: error: expected '=', ',', ';', 'asm' or '__attribute__'
> before 'char'
> mapows.h:123: error: expected '=', ',', ';', 'asm' or '__attribute__'
> before 'char'
> mapows.h:124: error: expected '=', ',', ';', 'asm' or '__attribute__'
> before 'const'
> mapows.h:125: error: expected '=', ',', ';', 'asm' or '__attribute__'
> before 'const'
> mapows.h:143: error: expected '=', ',', ';', 'asm' or '__attribute__'
> before 'int'
> mapows.h:144: error: expected '=', ',', ';', 'asm' or '__attribute__'
> before 'const'
> mapows.h:156: error: expected '=', ',', ';', 'asm' or '__attribute__'
> before 'const'
> mapows.h:158: error: expected '=', ',', ';', 'asm' or '__attribute__'
> before 'int'
> mapows.h:162: error: expected ')' before '*' token
> mapows.h:166: error: expected ')' before '*' token
> mapows.h:170: error: expected ')' before '*' token
> mapows.h:174: error: expected ')' before '*' token
> mapows.h:178: error: expected ')' before '*' token
> mapows.h:190: error: expected ')' before '*' token
> mapows.h:193: error: expected ')' before '*' token
> mapows.h:196: error: expected ')' before '*' token
> mapows.h:201: error: expected ')' before '*' token
> mapows.h:206: error: expected ')' before '*' token
> mapows.h:211: error: expected ')' before '*' token
> mapows.h:214: error: expected ')' before '*' token
> mapows.h:219: error: expected ')' before '*' token
> mapows.h:222: error: expected ')' before '*' token
> mapows.h:224: error: expected declaration specifiers or '...' before
> 'mapObj'
> mapows.h:225: error: expected ')' before '*' token
> mapows.h:229: error: expected ')' before '*' token
> mapows.h:230: error: expected ')' before '*' token
> mapows.h:232: error: expected ')' before '*' token
> mapows.h:321: error: expected '=', ',', ';', 'asm' or '__attribute__'
> before 'int'
> mapows.h:322: error: expected '=', ',', ';', 'asm' or '__attribute__'
> before 'gmlItemListObj'
> mapows.h:323: error: expected '=', ',', ';', 'asm' or '__attribute__'
> before 'void'
> mapows.h:324: error: expected '=', ',', ';', 'asm' or '__attribute__'
> before 'gmlConstantListObj'
> mapows.h:325: error: expected '=', ',', ';', 'asm' or '__attribute__'
> before 'void'
> mapows.h:326: error: expected '=', ',', ';', 'asm' or '__attribute__'
> before 'gmlGeometryListObj'
> mapows.h:327: error: expected '=', ',', ';', 'asm' or '__attribute__'
> before 'void'
> mapows.h:328: error: expected '=', ',', ';', 'asm' or '__attribute__'
> before 'gmlGroupListObj'
> mapows.h:329: error: expected '=', ',', ';', 'asm' or '__attribute__'
> before 'void'
> mapows.h:330: error: expected '=', ',', ';', 'asm' or '__attribute__'
> before 'gmlNamespaceListObj'
> mapows.h:331: error: expected '=', ',', ';', 'asm' or '__attribute__'
> before 'void'
> mapows.h:335: error: expected '=', ',', ';', 'asm' or '__attribute__'
> before 'int'
> mapows.h:346: error: expected ')' before '*' token
> mapows.h:347: error: expected '=', ',', ';', 'asm' or '__attribute__'
> before 'int'
> mapows.h:358: error: expected declaration specifiers or '...' before
> 'mapObj'
> 'layerObj'
> mapows.h:361: warning: 'enum MS_CONNECTION_TYPE' declared inside parameter
> list
> mapows.h:361: warning: its scope is only this definition or
> declaration, which is probably not what you want
> mapows.h:363: error: expected declaration specifiers or '...' before
> 'mapObj'
> 'layerObj'
> mapows.h:364: error: expected declaration specifiers or '...' before
> 'imageObj'
> mapows.h:365: error: expected '=', ',', ';', 'asm' or '__attribute__'
> before 'char'
> mapows.h:380: error: expected ')' before '*' token
> mapows.h:381: error: expected ')' before '*' token
> mapows.h:384: error: expected ')' before '*' token
> mapows.h:385: error: expected ')' before '*' token
> mapows.h:401: error: expected declaration specifiers or '...' before
> 'mapObj'
> 'layerObj'
> mapows.h:403: error: expected ')' before '*' token
> mapows.h:404: error: expected ')' before '*' token
> mapows.h:406: error: expected ')' before '*' token
> mapows.h:407: error: expected ')' before '*' token
> mapows.h:408: error: expected ')' before '*' token
> mapows.h:409: error: expected ')' before '*' token
> mapows.h:410: error: expected ')' before '*' token
> mapows.h:411: error: expected '=', ',', ';', 'asm' or '__attribute__'
> before 'char'
> mapows.h:417: error: expected '=', ',', ';', 'asm' or '__attribute__'
> before 'int'
> mapows.h:418: error: expected '=', ',', ';', 'asm' or '__attribute__'
> before 'int'
> mapows.h:419: error: expected '=', ',', ';', 'asm' or '__attribute__'
> before 'int'
> mapows.h:420: error: expected '=', ',', ';', 'asm' or '__attribute__'
> before 'int'
> mapows.h:427: error: expected ')' before '*' token
> mapows.h:435: error: expected ')' before '*' token
> mapwfs11.c:35: error: expected declaration specifiers or '...' before
> string constant
> mapwfs11.c:35: warning: return type defaults to 'int'
> mapwfs11.c: In function 'MS_CVSID':
> mapwfs11.c:35: error: expected '{' at end of input
> make: *** [mapwfs11.o] Error 1
> On Wed, Mar 19, 2008 at 10:34 PM, Steve Lime <Steve.Lime at dnr.state.mn.us>
> wrote:
>> Hi all: I've been beating my head against a configuration problem with Perl
> MapScript today that stems from changes
>>  made for RFC 24. I have multiple version of mapscript installed and it's
> fairly straight forward with Perl to do so, change
>>  1 line in mapscript.i and one in Makefile.PL. Until now that is. In
> plmodule.i there are references to mapscriptc and mapscript
>>  that must also be changed. I can do that and will also update the Perl
> README to reflect that additional step. Before I do
>>  so I was wondering if there were a more portable way to write plmodule.i so
> that it could automatically pick up on name
>>  change for the whole module. I don't how big a problem this is for other
> languages. Thoughts?
>>  Steve
>>  _______________________________________________
>>  mapserver-dev mailing list
>>  mapserver-dev at lists.osgeo.org
>>  http://lists.osgeo.org/mailman/listinfo/mapserver-dev
