[mapserver-dev] Re: problem with WFS DWithin
Paul Ramsey
pramsey at cleverelephant.ca
Thu Mar 27 11:25:03 EDT 2008
DWIthin(A, B, D)
should be functionally identical to
Distance(A, B) < D
so no, what you describe doesn't sound like a correct DWithin, Bart.
BTW, if it's implemented as
Intersects(A, Buffer(B, D))
it's incredibly inefficient.
P.
On Thu, Mar 27, 2008 at 8:19 AM, Bart van den Eijnden (OSGIS)
<bartvde at osgis.nl> wrote:
> Okay, it seems it only returns features if they are totally contained within
> the searchshape + distance (the buffered linestring).
> Is this the way DWithin is supposed to behave? I am not a geometry operator
> specialist unfortunately, but my expectation was to get any of the polygons
> containing the buffered linestring.
> A small buffer (500 m) selects nothing:
> http://www.osgis.nl/download/umn/dwithin1.png
> A bigger buffer (2500 m) only selects 3 polygons:
> http://www.osgis.nl/download/umn/dwithin2.png
> Best regards,
> Bart
> OSGIS, Open Source GIS
> http://www.osgis.nl
> --------- Oorspronkelijk bericht --------
> Van: Bart van den Eijnden OSGIS <bartvde at osgis.nl>
> Naar: mapserver-dev at lists.osgeo.org <mapserver-dev at lists.osgeo.org>
> Onderwerp: problem with WFS DWithin
> Datum: 27/03/08 14:59
> > Hi list,
> > I can't get a DWithin filter containing a LineString to work. I am using a
> > polygon layer. It doesn't select anything. Using 5.0.2.
> > A DWithin containing a Polygon works fine.
> > Any ideas what could be causing this?
> > Did anybody else experience the same thing?
> > Best regards,
> > Bart
> > http://www.osgis.nl
> mapserver-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
